lowering spring suggestion
11-19-2017, 10:08 PM | #2 |
298
Rep 650
Drives: Ferrari F430, E92 M3, 335xi
plenty of options, H&R, Eibach, etc... Even stock non-x springs should be Ok?
11-20-2017, 05:04 AM | #3 |
General
17371
Rep 18,769
Visit Turner Motor Sports website. Read up in the Suspension sub forum. Plenty of info for you.
11-20-2017, 10:50 AM | #4 |
New Lifetime Replacement Policy
821
Rep 11,738
11-20-2017, 11:07 AM | #5 |
166
Rep 429
Drives: 2011 e92 335xi
1. Eibach Pro-Kit springs for RWD (XI part doesn't exist):
What I have. Moderate drop. Soft spring. Good match with Bilstein B8 damper. Same rate as RWD ZSP spring. Car gets even lower over time because XI front is heavier. 2. H&R Sport: Made specifically for XI. Drops more than pro-kit. Stiff because spring rate is high to keep up with XI weight. 3. Dinan Sport: Drops 0.5" front/ 0" rear. Stiff for same reason as H&R sport. 4. OEM ZSP spring for RWD Same spring rate as pro-kit. About 0.8" front/0.6" rear higher than pro-kit (just assumption based on specs). This is what I'm looking to get because I'm tired of scraping front bumper. 5. BMW performance springs. Check this out too if you're interested.
2011 E92 335i xDrive
Pure Stage 1 | DV+ & Inlet | Injen Intake | M3 Cowl | ETS 5" FMIC & CP | Aquamist HFS4 Direct Port | CSF Radiator | Wagner Catted DP | BMW PE | Apex FL-5 | Michelin PS4S | 335is Engine mount | SDW Monoball thrust arms | UUC Swaybars & SS Brake lines | Bilstein B8 | Dinan Springs & Shock mounts | Whiteline RSFB | M3 Rear Control arms | Manzo Toe arms | Wavetrac LSD Last edited by Supermoon; 11-20-2017 at 11:12 AM.. |
