11-17-2017, 03:47 PM | #1 |
186
Rep 476
What to look at to cure lots of smoke upon cold start?
Hello.
My wife's 2012 328i with 65k miles puffs out quite a bit of smoke when I first start it cold. I recently had to replace a thermostat and did see some oil buildup in the intake manifold so I am assuming it gets there through turbo side. Is this basically a sign of soon to come turbo rebuild or is there anything else I can look at to maybe correct the situation? The car itself runs and drives just fine, no noticeable engine power loss. The video http://www.youtube.com/watch?v=NEnxb2RqW3A |
11-17-2017, 04:14 PM | #2 |
8245
Rep 16,086
There's more than one source for oil making it's way into the cylinders. Could be the turbos, could be valve stem seals. It's not rings, they wouldn't account for oil accumulating when the engine is shut down, and the smoke would be there all the time.
Zamorskii186.00 |
11-17-2017, 04:39 PM | #3 |
198
Rep 351
could be turbo seals or valve stem seals like dude above me said.
is there a pcv system on this car that could be causing some oil to accumulate?
2013 335i M-Sport 6MT, MPE, VRSF CP and IC, BM3 Stage 1
2006 330i 6MT, Sport Package - sold |
11-18-2017, 01:23 AM | #6 |
2JZ-GTE
3045
Rep 3,996
I hope it's cheap fix
11-18-2017, 05:11 AM | #7 |
38
Rep 64
You maybe covered under warranty. I had a 2012 328i with N20 engine and received a Limited Warranty letter regarding, "Engine Oil Feed Line to the turbocharger." The warranty was extended for 10yrs/120K miles. I was the original owner and received this letter after I sold the vehicle, so if you are the second owner you may not have received such a letter. There is also discussions about this issue here are two I found.
http://f30.bimmerpost.com/forums/sho...oke+cold+start http://f30.bimmerpost.com/forums/sho...ht=white+smoke |
Zamorskii186.00 |
11-18-2017, 01:01 PM | #8 | |
186
Rep 476
