TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > General BMW X6 and X6M Forum
      05-21-2008, 10:31 PM   #1
OpenFlash
1736
Drives: A Lot
1st MSD v81 Tuned
A good customer of ours brought another one of his cars to us this afternoon.
A brand new N54 powered X6!:
Interior shot:
Engine bay:
PnP v3 PROcede installed (but not tucked away):
Initial Obvervations:
The ECU compartment is very easy to get to. Only takes 30 seconds or so to remove the two plastic overs. The ECU cover itself is also easy to get off just as long as you realize that there is a clip at the back. ECU compartment is smaller than normal which means that you have to carefully position the PROcede, v2 ballast and relay in the same "shelf". It's tight but it will all fit. The remote switch box will have to sit on top of everything. The is also very high off the ground making it a bit difficult to work on (duh). If I was a foot shorter, I'd have given up
The charge plumbing on the engine is VERY different from the 135/335/535. So different, in fact, that it took me a good 5 minutes to figure out where the piping goes. Boost control solenoids are nearly impossible to see or get to. Thank god we don't mess with them or the hoses
Other than that, the Plug n Play install was simple. Car started right up with the "Doomsday" map that I've been developing on my fully modded 6MT 335. As expected, I had to make some changes to account for the 6AT. There were some other MSD 81 differences that I logged. But seeing how the last thread turned out, i'll just keep them to myself. Also, no dyno results yet. We'd have to go to an AWD dyno for that.
Bottom line: Car is fast. No limps. No throttle closure. Just good power.
BTW, Doba S and I went on a fast backroad drive and the X6 is just outrageous. Minimal body roll and incredible mid-corner balance. In many ways, it handles better than my 335 and that is no joke. It's got a bitchin' torque vectoring rear diff that sends torque to the outside rear wheel while cornering. This pretty much eliminates understeer completely. Same set-up as the EVO X, btw. I never thought I'd want an SUV. But this car is really is amazing.
Cheers
shiv
      05-21-2008, 10:35 PM   #2
eunosracr
157
Drives: a car
Shiv,
Is v3 available for non-local purchase yet?
TIA
      05-21-2008, 10:41 PM   #3
Robertbog
Robertbog's Avatar
69
Drives: 335i
Need help with picture quality? .
Nice work, wtf "bitchin" open diff?
      05-21-2008, 10:45 PM   #4
Lane
Several N54 cars, V1,3, V2.0.2, and V3.1
12
Drives: N54s
He is not "bitchin" open diff
      05-21-2008, 10:46 PM   #5
Digital.James
Digital.James's Avatar
119
Drives: GT4, Raptor.2, Tuono 1100F
The X6 is seriously growing on me. Seems like a way to get practicality and performance in a nice package.
      05-21-2008, 10:47 PM   #6
OpenFlash
1736
Drives: A Lot
lol.. I had it on Macro mode in the first shot. And what open diff are you referring to?
      05-21-2008, 10:59 PM   #7
Biturbo335i
Biturbo335i's Avatar
17
Drives: AW/Coral E92 335i Coupe
Any hidden codes or ways to avoid them on the MSD v81 Shiv?
2007 E92 335i - Alpine White, Coral, 6 Speed MT, Premium, Sport, Painted Reflectors, GT thunder Angel Eyes, M-Tec Fogs, Cyba CF Kidney Grills, Black OEM Lower Mesh, OEM Aero-Lip, 19" Staggered Matte Black VMR CSL Reps, General Exclaims - 235 Front and 265 Rear, Black Window Trim, BMS Dual Filter Intake, Britalman Catback Exhaust, CF Mirrors, CF M3 trunk lip, 5% Tint, Lamin-X Tinted Tails, Split Second Turbo Tuner.
      05-21-2008, 11:14 PM   #8
MarinoB
MarinoB's Avatar
Croatia
282
Drives: '17 F80 M3
that didnt take long
      05-21-2008, 11:16 PM   #9
Robertbog
Robertbog's Avatar
69
Drives: 335i
Isnt the diff on the X6 open, sounds like the torque biasing you are referring to
Cheers
shiv
      05-21-2008, 11:20 PM   #10
OpenFlash
1736
Drives: A Lot
Nonono... the X6 rear diff isn't open. It's way more sophisticated than anything you will find on any production car (other than the evo x or honda crv). It biases the torque left or right based upon steering angle, yaw rate, cornering G, etc,. Basically tunes out understeer. Also makes the car incredible stable under braking.
Shiv
      05-21-2008, 11:22 PM   #11
OpenFlash
1736
Drives: A Lot
Primary goal was to get the car tuned properly. With no limps or throttle closures. We got that. Also kept STFT reasonably small which should make it diagnostically invisible. Really depends on how tight the diagnostic tolerances are. But I can't read hidden codes so I cannot be sure if they are there or not. In the end, if you tune your car, you need to know the risks. We can minimize them in a big way. But risks are always there.
Shiv
      05-21-2008, 11:35 PM   #12
satinghostrider
satinghostrider's Avatar
Singapore
178
Drives: 2018 F80 M3 ZCP LCI II
Can I have the pnp harness and V3 pls?
2018 F80 LCI II ZCP ///M3 Mineral White M-DCT| Sakhir Orange Interior| |M Performance Exhaust|
      05-21-2008, 11:37 PM   #13
eunosracr
157
Drives: a car
+10000 when can we get this Pnp v3?
      05-21-2008, 11:41 PM   #14
satinghostrider
Singapore
178
i am still waiting for my car to come back from the dealer for my ticking problem. I wanna use the pnp as i gotta go in again after that for a scheduled service. Sux if i have to keep taking it out w/o a pnp harness. Plus i am off boost for 2 months now. Feel like a virgin again.
      05-22-2008, 01:51 AM   #15
OpenFlash
1736
Drives: A Lot
I just want to test a couple more things before we release any more v3s. With the new ECUs/Progman version, I'd like to get all of our PROcede kits on the same playing field and this is the last opportunity to do so. We will have v3 PnP harnesses available a la carte soon. Just want to make sure that we don't have to release any more updates in the future. They are logistic nightmares
Shiv
      05-22-2008, 02:03 AM   #16
XPO186
XPO186's Avatar
Philippines
128
Drives: E92 335i
Ha ha ha... Aleks wastes no time...
      05-22-2008, 02:14 AM   #17
M3EST
Rear wheel drive fanatic
M3EST's Avatar
No_Country
51
Drives: M3 E30-1M-M4
1987 BMW M3  [0.00]
2011 BMW 1M  [10.00]
Pnp is something that everybody would like to have.So please make it soon available for every procede customer.
      05-22-2008, 02:19 AM   #18
hellrotm
4143
Drives: F80
He needs that extra power, the X6 is a PIG!
A ~5,000 pound vehicle. With only 4 seats.
      05-22-2008, 02:25 AM   #19
OpenFlash
1736
Drives: A Lot
After driving on my favorite backroad this afternoon, the word 'Pig' does not come to mind. Really fun car to toss around. Seriously. I was shocked by how well it handled right up to and beyond the limit.
      05-22-2008, 02:34 AM   #20
hotrod182
hotrod182's Avatar
788
Drives: 2023 i4 M50
Its going to be amazing seeing the TT V8 setup in person when they come out. Wonder how mild the boost is going to be set on them. Talk about being easy to change the turbos, they are right on top of the engine. I can swap out the turbo in my Grand National in 15 minutes.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra,
2008 Black 335i Sedan. 11.11@ 129.47 mph
2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds
2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy)
      05-22-2008, 06:49 AM   #21
e90AW335i
137
Drives: e90 335i
Nice work Shiv. I look forward to trying out a V3 very soon.....
      05-22-2008, 07:51 AM   #22
RMRC
RMRC's Avatar
19
Drives: 2011 E90 335d
Shiv
Sounds similar in operation to Acura's SHAWD.
