11-14-2017, 12:57 PM | #1 |
Rep 44
Newbie Question: 225 40R 18 Compatible?
Hi,
Newbie here. I just purchased a 2018 i430 Xdrive Grand Coupe with M Sport Package. As the car comes with performance tires, I need to get winter tires. I found an awesome deal on 225 40R 18, but specs show I should be using 225 45R 18. Will this be an issue, or should I be ok with the 225 40R 18? Thx! |
11-14-2017, 03:46 PM | #2 |
1863
Rep 5,140
I don't recommend 225/40-18.
Those tires are 3.5% shorter than OEM size and results in increased fender gap, less wheel protection, reduced comfort and a speedo that is even more off than with OEM tires. |
11-14-2017, 04:57 PM | #3 |
Rep 44
11-15-2017, 06:59 PM | #4 |
169
Rep 326
I like to use this website comparing tire&wheel setups to OEM: http://www.rimsntires.com/specspro.jsp
11-15-2017, 08:10 PM | #5 |
96
Rep 219
It works height wise, but width will be tight on stock wheels in the front. Those tires are 1” wider -30mm- so call it 1/2” on either side of the wheel in width.
What wheels are you going to run these on? An 8.5” or 9” wheel is a better fit for a 255 tire, but will be an issue in the front. You are better off with a 225/45-18 all around. Sorry |
11-15-2017, 09:25 PM | #6 | |
309
Rep 641
11-15-2017, 09:48 PM | #7 |
Rep 44
11-16-2017, 10:12 AM | #8 | |
309
Rep 641
I run 255/40/18 square with no problems. |
11-16-2017, 12:03 PM | #9 |
8245
Rep 16,088
Where winter tires are concerned don't go wider, as you end up with less traction. It's counter-intuitive, but true.
https://blog.tirerack.com/blog/hunte...ter-for-winter |
