11-13-2017, 11:12 PM | #1 |
Rep 26
are LED's or halogens better for downroad visibility
Hi
I have factory halogens without halo's. Didn't even realize it til after I bought the car, I assumes all BMW's came with halo's. anyway I recently bought some ebay headlight housings to replace mine & am wondering if I should go with LED replacement bulbs or halogens. Main concern is downroad visibility (how far & how well I can see at night) secondary concern/preference is color temp looking for a white light probably about 6,000k. Have LED's gotten to a point yet that they can compete with or perform better than top shelf halogens like sylvania? If you have any specific brand/bulb to recommend please do so |
11-13-2017, 11:43 PM | #2 |
134
Rep 306
Halogens were revolutionary in the 70s when they replaced incandescent.
This Century they fail all the Highway Safety test. HID Xenons blow them away as do SOME LEDs, though the F30 Standard LEDs also perform poorly on the safety tests. |
11-14-2017, 07:08 AM | #4 | |
8245
Rep 16,086
http://f30.bimmerpost.com/forums/sho....php?t=1377259 |
Bavarianborn2.00 |
11-14-2017, 08:09 AM | #5 |
714
Rep 1,329
Practically speaking, the best consistent downroad lighting seems to be HID. LED seem to have potential, but still some issues with execution. Mostly they are a selling feature and make the car nice to look at and less expensive to manufacture then HID.
I have factory LED - non adaptive, and they are not even close to the best headlights I have had on a car.
2002 325i sport - sold 2009 135i M sport - sold
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT |
11-14-2017, 09:21 AM | #6 | |
Rep 26
I will however post some pics of the housings & let you know what the quality looks like when I get them. |
11-14-2017, 09:30 AM | #7 |
Rep 26
I agree that hid is great, I have a Porsche Boxster s with them & my wife’s Acura RDX has them as well. Stupid me assumed the bmw would as well, never even thought to check.
Yes led’s often have a much higher lumen output, but that doesn’t always mean you can see down-road better. If they don’t reflect & project properly. You can see the road immediately in front of Your car brilliantly, so well that it’s can be distracting. But, what you really want is to see far down the road. Many of the articles I’ve read say led fail at this but are getting better, these articles are all a couple years old. So, are they there yet or are we still waiting for it to be better? |
Danddd74.50 |
11-14-2017, 11:37 AM | #8 |
147
Rep 477
I have the LEDs on my 2017 and had the halogens on my 2014. The LEDS are better, but not markedly so. FWIW, the halogens on a 2017 are definitely better than on the 2014.
The present LEDs emit a very white light. They don't project down the road all that well, but they're adequate. The light is also somewhat uneven. The real issue to me is the lighting towards the corners. When stopped at a stop sign and wanting to make a right turn, you don't get much lighting towards the crosswalk. Turning on the fog lights helps a great deal with this, and some here have coded the appropriate fog light to come on with the turn signal. I haven't coded my car because I'm convinced I'll unleash a nightmare. I'm an engineer and see this kind of thing all the time. |
11-14-2017, 11:44 AM | #9 | |
714
Rep 1,329
11-14-2017, 12:03 PM | #10 |
7635
Rep 3,440
I have adaptive LEDs, and these are the best headlights I ever had (two previous ones had HIDs). Non-adaptives look kinda meh to me, but still better than halogens.
However, the OP here is not asking us about OEM headlights. He has some unknown aftermarket thing going, and the result of that could be anything at all. China has many factories. |
11-14-2017, 12:25 PM | #11 | |
147
Rep 477
11-14-2017, 12:35 PM | #12 | |
714
Rep 1,329
I research and do my codeing once shortly after living with the car for awhile, so it is way long in between codes so 1. I don't really retain the knowledge and 2. the model and software are different each time, so not really worth becoming proficient each time all over again.
11-14-2017, 01:18 PM | #13 | |
8245
Rep 16,086
11-14-2017, 01:25 PM | #14 |
56
Rep 108
To the OP, as far as an LED bulb recommendation, here's what'd I'd recommend:
http://www.vleds.com/shop-products/l.../micro-h7.html The LEDs are located at the same spot as the filament of a typical halogen bulb within the casing, and the size makes it reflect much better in the reflector housings than most HIDs or LED bulbs will. Most others light up in a different spot, so it throws the light all over the place from the housing. Still not perfect, but they put out more usable light, and reflect it very well all things considered. |
11-14-2017, 04:09 PM | #15 | |
Love rollin in my wagon
75
Rep 216
11-14-2017, 05:53 PM | #16 |
56
Rep 108
Yep, same here. Going back to halogens after my previous three cars all had HID was tough, so I researched to find the best solution. These work quite well at putting out useable light without blinding other cars.
I went with the 5k color, don't care much for the blue tint 6k and above have. The fan also does a great job of keeping the bulbs cool. I had already coded out the bulb checks so no errors, etc. |
11-14-2017, 08:50 PM | #17 |
7635
Rep 3,440
11-14-2017, 09:57 PM | #18 | |
65
Rep 240
I would consider an Adaptive LED retrofit down the line if they do sell one that can be Plug and Play. Better yet, I'd be happy to step "backwards" and put HIDs in projectors into my 2017 if I could. My wife's 2014 Honda Odyssey Elite has the HIDs in projectors and it lights up the night road much better than my M Sport. |
otay826.00 |
11-15-2017, 01:35 AM | #19 |
2JZ-GTE
3045
Rep 3,996
I have the standard F 30 LEDs and they suck. They are just aimed too low and they're auto adjusting. I would mention this to the BMW dealer next time it's in for maintenance but I'm sure they'll break something in the process of diagnosing it.
11-15-2017, 05:40 AM | #20 |
1363
Rep 2,495
I've got the Adaptive LED's in my 440 and they are amazing, love them. Even better than the bi-xenons in my last car - 640.
Very bright and I have no issues when in dip, full beam or adaptive. Halogens are awful.
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
11-15-2017, 07:37 AM | #21 |
353
Rep 1,245
Personal experience - /14 BMW F30 with Xenon HIDs versus '16 Honda Civic Touring with LEDs.
The LEDs are brighter, but the Xenon HIDs win the day for me every time. Throw in adaptive headlights, and you have a winner in my book. |
11-15-2017, 08:19 AM | #22 |
Schmollbraten
12512
Rep 1,985
Had adaptive LED's on my F32 and miss them very much, never had better lightning at dark night. Actually returned with other car to xenos, no match.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
