11-10-2017, 10:57 AM | #1 |
22
Rep 93
High pitch noise
Hello guys I need your help. I have a 2014 335i all stock with about 30k on the clock. The car is making a high pitch sound only above 15mph the sound does not vary with speed or change in pitch. Its been at dealer now for about 2 weeks with no luck. They had tried replacing my brakes, the fuel pump, and the my put a different set of rims and tire on. Any ideas suggestion?
Thanks in advance |
11-13-2017, 09:28 PM | #4 |
967
Rep 2,655
I have the same noise in my cabin. Waiting to hear back from the dealer to schedule a service.
High Pitched Whistle in Cabin http://f30.bimmerpost.com/forums/sho....php?t=1439331
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Tune Stage 2 - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI
11-14-2017, 11:19 AM | #5 | |
22
Rep 93
11-14-2017, 11:29 AM | #6 | ||
967
Rep 2,655
11-14-2017, 11:33 AM | #7 |
22
Rep 93
11-14-2017, 03:43 PM | #8 |
56
Rep 108
While researching this on older threads, I came across this from another member:
"I have a 2013 328 that had this exact same issue. Took it to the dealer and did a test drive with the shop foreman in the car. Surprise surprise it didn't happen then. Fortunately the foreman knew right away once I explained the symptoms. He was able to reproduce it by turning off the A/C but leaving the fan on. He said they recently received a service bulletin about this issue caused by the heater expansion valve. I have not experience this issue again after the dealer replaced the expansion valve (Feb 2016). Whereas before I was getting this issue once every few weeks, especially on the warmer days." |
11-14-2017, 05:54 PM | #9 | |
22
Rep 93
11-24-2017, 12:19 AM | #15 |
13
Rep 26
I'm also experiencing a similar issue. I can hear a high pitch and a slightly lower one. It isn't related to rpm but to wheels speed.
The car was also diagnosed with a faulty differential and it's due to service on Monday. Hopefully it will be ok. The car is 3 weeks old I've now got a new differential and the car is quiet again. Hopefully it will stay so Last edited by LaGSa; 11-28-2017 at 03:40 PM.. |
11-28-2017, 10:17 AM | #16 |
Rep 1
Just a few months before the warranty ran out I had this noise and once you tuned into it it was a pain - Dealer changed something on the drive train to fix it - car was in for 2 days. It has solved the problem.
12-05-2017, 05:43 PM | #17 |
22
Rep 93
What's up guys just wanted to let everyone know. That I got the car back and it was the rear diff. The sound is gone and I'm super happy
uncleruckus129.50 |
