11-07-2017, 01:13 PM | #1 |
Rep 17
Clicking and Clunking
I know this issue has been addressed several times on the forums but so far I have only seen that people have encountered the clicking when turning (usually at low speed). I know that the issue with the clicking is related to wheel torque and can be easily fixed but I am concerned with an additional clunking sound I hear when I am breaking and nearing a stop.
As I approach the stop I will hear it once, normally every time I am stopping and not listening to music I will hear it and it bugs me. The owner before me took very good care of the car, I assume he just did not notice this as you do have to have the windows down and music off and listen carefully. I just want to know more about the issues before taking them into Service so that no time is wasted trying to diagnose the problem. Thank you all in advance! |
11-07-2017, 02:29 PM | #2 |
230
Rep 555
Take it to the dealer, I had this happen to me, they replaced my wheel bearings. I have heard of them just tightening up the lugs or some other remedies. In my case though, they replaced both front wheel bearings.
11-07-2017, 04:59 PM | #3 |
Rep 17
Do you really think the clunking is coming from the wheel bearings? It sounds like it is emanating from under the front portion of the car, whereas the clicking sounds more outward.
11-07-2017, 05:05 PM | #4 | |
230
Rep 555
If you have someone that can help you out, go to an empty parking lot, and try recreating the sound, can have them walk near the car as its coming to a stop. Because of acoustics inside the cabin, it can be misleading. Judging by your description, I would doubt it is actually wheel bearings, it could be something with your brakes maybe? suspension?
11-07-2017, 07:06 PM | #5 |
NewFinishColumbia/detailer
604
Rep 2,096
Probably the best way to figure out what to check next is to eliminate the bearings.
Lift your wheel up. Push on the top and bottom of the tire. If there's movement then it's your bearings. Push at the 3 and 9 clock positions. If there's movement that direction then it's a suspension component. Make sure you make the steering wheel lock before doing this so that the wheel can't turn. Make sure your lug bolts are torqued to 105 ft lbs as well. If you have recently had tire work done a tech may have short cut the process and used the impact to reinstall your wheels on the car. When torquing make sure you alternate the position when tightening to seat the wheel properly. Pull the wheel off and check all the brake pad retaining clips. If one has broken or cracked then it would cause the pad to shift ever so slightly when you brake until it stops. That could potentially be the clunking. This should help you narrow down what it is.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
11-08-2017, 11:27 AM | #6 |
5557
Rep 5,374
Are you on the stock suspension? Front end clunking can usually be attributed to a loose/worn anti-roll bar link or a strut top hat. The top hats in these cars have had a history of prematurely wearing out and the bearing will start to clunk, especially at slower speeds where more things can be heard. These top hats wear out quicker on car with lowering springs and/or camber changing parts which put additional stress on the bearing.
Lastly, the clunking could also be worn pads shifting inside the caliper under initial braking. |
11-08-2017, 11:40 AM | #7 | |
Rep 17
If it is the suspension, is it an easy fix? I am scheduling service for next week. |
11-08-2017, 12:24 PM | #8 | |
5557
Rep 5,374
11-08-2017, 12:33 PM | #9 | |
341
Rep 1,184
Probably just then pads settling in though. |
