M2 Technical Topics > Track / Autocross / Dragstrip > Brake Pads Recommendation for TRACK use
      11-02-2017, 01:38 PM   #1
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Hi,
I am planning on going to the the track with my car next year and I am looking for your recommendation on what pads to use. I will swap pads only for the track (is it overkill?)
rich8566608.50
      11-02-2017, 02:13 PM   #2
dvas
dvas's Avatar
520
Drives: 2017 M2 - Mineral Gray, 6spd
I've had a good experience with PFC 08s. They have good bite but excellent modulation.
Additionally, they are designed as an endurance pad and will last a long time. I have ten days on mine and probably have about half life on them.
Appreciate 7
Benzima1324.00
rich8566608.50
elim11423.50
gsrbri559.50
5.M0NSTER3353.50
M2guru406.00
      11-02-2017, 02:20 PM   #3
tux2005
234
Drives: 2017 M2
If you have no or very little experience then stock might be fine depending on the track. I'm an intermediate driver at a Canadian Tire Motorsport Park/Mosport I am using Pagid RS29s but I might be able to get away with stock, just. Only a couple corners need hard braking. I had also used stock pads at the Nurburgring while on ED but I was not pushing the car hard at all.
I think the RS29 are probably the most popular for the M2, lots of people are using them. I've seen a few others on here using PFC, Endless and a few Hawks.
I bought my RS29s from a fairly local shop but had them shipped to me, it was expensive but I think shipping from the US with customs clearance would have been pretty close in price.
I've done 2 weekends on the pads so far with tons of pad left. I swap between the stock pads for street and the RS29s for the track, they squeal and rattle way too much for me to leave them in.
Appreciate 3
Benzima1324.00
rich8566608.50
DrKevM52276.00
      11-02-2017, 05:45 PM   #4
kaosHunter
kaosHunter's Avatar
South Africa
23
Drives: 2010 Black 125i Coupe E82
My experience with the OEM pads is they overheat and drop uneven pad deposits on the disk causing shuddering. This only gets worse overtime and eventually a new disk is needed.
Changed over to endless pads and don't have the problem of shuddering after a track day now.
      11-06-2017, 04:30 PM   #5
gsrbri
gsrbri's Avatar
560
Drives: F87 6MT
I've used Pagid RSL 1 and RS29 previously. Switched to PFC 08. I really like the bite/characteristics of the PFC 08. Also, they do a much better job at managing rotor deposits and scraping-off bedded brake material when cold, so if you're swapping between street/race pads between track days, the PFC 08, in my opinion, has been MUCH better. My $.02
Appreciate 3
rich8566608.50
M2guru406.00
      11-13-2017, 12:48 PM   #6
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Get track pads, flush fluid. I use Hawk DTC60 for milder R comps or DTC70 for aggressive tires.
Appreciate 2
rich8566608.50
gsrbri559.50
      11-18-2017, 10:08 AM   #7
rich8566
rich8566's Avatar
609
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
Get the Pagid RS29s. Do NOT use the stock pads on track. They will "melt" and leave uneven deposits on the rotors which will result in a horrible brake shudder. Ask me how I know!
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
Appreciate 6
Benzima1324.00
gsrbri559.50
AmuroRay2307.00
pal433.00
      11-19-2017, 03:00 AM   #8
M2 Belgium
27
Drives: BMW M2
+1 on the pagids. Easy to swap out.
rich8566608.50
      11-22-2017, 10:51 PM   #9
SEAT TIME RULES
SEAT TIME RULES's Avatar
1105
Drives: 20 BMW M2C 17 Mazda MX-5 RF
2020 BMW M2C  [5.00]
Another option is to run a rotor friendly track pad.
I got sick of swapping out pads at the track especially when I had a couple students to worry about as well.
I've had outstanding results running these 3 pads both on the street and at HPDE's.
Raybestos ST43's
Carbotech 10's, or 12's
Porterfield R4's.
All three are acceptable pads for street use even in freezing temps.
All three will not eat rotors when cold (most track ready pads will destroy rotors until they heat up)
All three have excellent initial bite, have 1200+ degree heat tolerance, zero fade.
All three will dust a ton and squeal as you stop unless they're hot.
Right now my go to pad is the Carbotech 12's.
Their was a split within the company and a additional brand G-Loc offers similar options.
HTH,
HAZMAT
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
Appreciate 2
Benzima1324.00
Nella_0.00
      11-27-2017, 04:02 PM   #10
Noel911
90
Drives: 2017 M2 & 2019 Golf R (Daily)
I use Hawk DTC60 on the M2 and also used them on my old M3. Have always had good luck with them. The only issue is that that brake dust in the rain is tough to remove, but that is a small price to pay, IMO. Good pad and a good value. Swapping pads is extremely easy on this car too, especially if you disconnect the brake pad sensors and permanently zip tie them out of the way.
As others have said, if this is your first time on the track. Just take your car there stock and enjoy. No need for track pads yet. Good luck!
      11-27-2017, 06:50 PM   #11
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Thanks! I will go all stock then.
      12-01-2017, 02:19 PM   #12
Hossel19
63
Drives: M2
Hi Benzima,
If you are planning to go with BMWCQ next summer to Tremblant you must change your brake oil in April. They will not accept brake oil older then 6 months for a good reason.
Also regarding the pads, last summer a student in the intermediate group ran with stock pads at tremblant and ended up with uneven pad deposits causing lots of vibration upon braking during the afternoon. I saw him at the following event and he had bought track pads.
My suggestion would be to:
1) buy pagid RS29 online during boxing week (they usually have good promotions)
2) change your brake oil in April once the car is out of storage
Hope this helps and see you on the track next spring
      12-01-2017, 05:47 PM   #13
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Originally Posted by Hossel19 View Post
Hi Benzima,
Thanks for feedback!
      12-05-2017, 12:35 PM   #14
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Where do you suggest buying them from?
      12-11-2017, 11:12 PM   #15
Hossel19
63
Drives: M2
Bought mine at HPAutosport. They advertise on this forum.
PM them during boxing week and they can send you discount codes.
Appreciate 2
      12-13-2017, 03:54 PM   #16
mailman411
Drives: MY17 M2
now i know too... unfortunately.
Appreciate 2
rich8566608.50
      02-04-2018, 07:40 PM   #17
chief1richard
Life is on the Track, the rest is just waiting.
chief1richard's Avatar
382
Drives: At the point of 7,000 RPM's
2018 M2  [0.00]
Just bought my Pagid RS29's from Autosport. My first upgrade on M2. Next will be camber plates, and possibly tires.
rich8566608.50
      02-07-2018, 09:40 PM   #18
matty_f
on restriction from buying more cars
No_Country
239
Drives: 24 M2, 18 GT3T, 16 LR4, 67 912
Started shopping for RS29s and wow they are pricey. Did anyone get any coupon action from Autosport?
I know the old Porsche saying: “which part did you think was gonna be cheap the Porsche or the racing part.” Guess the same is true for BMW too.
      02-09-2018, 03:52 PM   #19
Shayan55
Shayan55's Avatar
340
Drives: F90 M5
2105 BMW M235I  [0.00]
I run ferodo DS1.1's and i love them
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct
Hmu on Ig: @n55_shayan
      04-09-2018, 06:34 PM   #20
eeyang92
319
Drives: LBB M2 LCI 6MT
I learned the hard way too
Going to buy a set of RS29's to scrape off the deposits + use on track days from now on.
      05-02-2018, 04:08 PM   #21
chief1richard
382
2018 M2  [0.00]
Pagid RS29 Pads
Just installed my Pagid RS29 pads and have a loud clunking noise in front set. OEM pads had ears on the fronts. The Pagids don't. Is this normal?
      05-03-2018, 09:40 AM   #22
tux2005
234
Drives: 2017 M2
Yes, it's normal, the RS29s don't come with anti-rattle plates so they are loud when changing direction and they'll also rattle a bit over bumps. I love them for the track but I could never live with them on the street, they're too noisy.
m2
