10-28-2017, 05:06 PM | #1 |
Rep 12
oil filler for N47
Hi Bimmers,
Just get a silly question, I put a new oil filter on my X3 D20, but have no idea this copper ring? is it for oil drain? or should I put it on the oil filler? thanks mates |
10-28-2017, 10:03 PM | #2 |
986
Rep 2,199
It's meant for the drain plug on the oil pan.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
10-29-2017, 01:23 AM | #4 |
Rep 12
I found this oil filter installation is very tricky,
1, I try to install this oil filter as pic 1 below, "align the filter and push in" then result in oil leaking!!! I found many many oil mark on my floor in two days, 100% sure I tighten the oil filter and replace the rubber ring correctly. 2, then I pull it out, and this time I attach it to the cap first (pic 2), and " align the filter and push in", only found few drops in these two days ( not sure why still have oil drops!!!) I just wonder which methods is correct? and why I still get oil drops thanks mates |
10-29-2017, 11:37 AM | #5 |
No 55mph
1622
Rep 8,476
When you remove the oil cap the oil filter normally stays on the cage that is part of the cap - so upon changing out the filter I install the filter on the cap/cage assembly prior to putting cap back on - basically just the way it came out of the housing
I
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
10-29-2017, 05:27 PM | #6 |
986
Rep 2,199
Me too! And make sure that big O-ring is in the correct groove on the cap.
10-29-2017, 05:39 PM | #7 | |
Rep 12
Thanks 1QuikWS6 mate, I think you are right and I did the same way likes you in the second time, but still found few drops (2-3 overnight) in these two days (228 and 29 Oct), dont know why but hope they are from my last stupid installation. |
10-29-2017, 05:43 PM | #8 |
Rep 12
Thanks John, yes I did check that rubber o ring is in the correct groove because I was thought that is the problem but not, now looks like I follow the pic from the internet that push the filter into housing first before attaching it to the cap!!!
