M2 Technical Topics > Track / Autocross / Dragstrip > Stud conversions - who is good?
      10-23-2017, 12:54 AM   #1
ZPrime
I INDIC8
ZPrime's Avatar
612
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
See topic.
I'd like to go for a kit that uses M14x1.5mm thread pitch on the nut side instead of our stock 1.25 pitch, because there are more nut options in M14x1.5 (I already own a set of silver and black Gorilla nuts in this size from my Audi). I know these kits exist, but not all of them change thread on the wheel/nut side of the stud.
I don't plan on using spacers, I'm not into stance, so I don't need or want super-long studs. I'd rather order wheels that fit correctly / have correct offset. I was just going to stick with the stock wheels for summer, I'm grabbing a set of 18s for winter, and then depending on how much track work I do, I might find a square track/autox setup but that is still TBD.
Car will see salt so studs need to be weather-resistant.
2004 Matrix XRS 6MT => 2008 VW R32 DSG => 2012 Audi TTRS 6MT => 2018 BMW ///M2 6MT
I'm an IT guy by trade and tech nerd by choice.
I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway.
I'm also a fan of aural pleasure.
      10-30-2017, 12:16 PM   #2
emdeuce
197
Drives: M2 ZL9 6MT
Check out Motorsport Hardware. I'm currently running their studs and lug nuts and they've been tried and true on and off track.
The specific kit you'd probably be interested ing:
https://motorsporthardware.com/produ...-14x125-14x15/
Good luck!
Living Life Turn After Turn!
[/url]
F87 M2 Performance Edition - 2017-current
F15 X5 35d - 2014-2017
E36 M3 - 2009-2016
      10-30-2017, 02:14 PM   #3
twin fed
Doc Brown
twin fed's Avatar
1176
Drives: 2016 MG MT M2
Originally Posted by ZPrime View Post
See topic.
I have this set for sale BNIB that I will give you for a great price. They are 14x1.25 only but they are very strong and Tire Rack uses them on all their cars that they test tires for, even on the track. If you are interested LMK. They are perfect for what you are looking for. They are open ended lug nuts with bull nose studs and come with the installation tool. The only reason I did not use them is that they are a little to short to run larger spacers. But if that is not a concern for you it's ok.
Appreciate 2
ZPrime611.50
gsrbri559.50
      10-30-2017, 08:20 PM   #4
ZPrime
I INDIC8
ZPrime's Avatar
612
2018 BMW M2  [9.50]
I don't plan to use spacers, but I want something that converts to 14x1.5mm thread pitch because I have two sets of bolts in that size (the duplex chrome and duplex black chrome) already.
So I actually don't want super-long bullet nose studs, because I want to use these closed-end bolts.
Largest concern is that I need whatever to be able to hold up to the elements; we get road salt aplenty here. I've had some stud kits in the past (on VW/Audi) that are black-oxide coated and they rust... not good.
      10-30-2017, 09:40 PM   #5
ags28
26
Drives: 2017 LBB M2
studs
Hey there. I'm interested in those studs. How much do you want for them? They will bolt right on my stock M2, correct? PM me if you wish......
      11-02-2017, 02:09 PM   #6
ZPrime
I INDIC8
ZPrime's Avatar
612
2018 BMW M2  [9.50]
Good luck!
How does their hardware hold up to "the elements?" Have you had it in snow / salt? Any idea what the length of the stud is from the tip down to the base of the 14x1.5 threads? I have these ~2" deep closed-end nuts that I want to use, but if the stud is too long then the nut won't make it all the way down.
      11-02-2017, 02:13 PM   #7
emdeuce
197
Drives: M2 ZL9 6MT
Good luck!
These stud are definitely way too long for closed ended nuts. Maybe you can call and see if they can source studs that would suit your needs?
[/url]
E36 M3 - 2009-2016
      11-07-2017, 12:35 AM   #8
ZPrime
I INDIC8
ZPrime's Avatar
612
2018 BMW M2  [9.50]
I've been looking around and it seems like all of the studs on the market are crazy-long, presumably to allow for thickass spacers... which I don't get, because ideally you want zero spacers on a track-day car, and track days / frequent wheel swaps are the only thing that really justifies a stud conversion at all.
I've found maybe one or two options that are shorter than 70mm overall length, but they are m14x1.25 thread which drastically limits your nut choice (and I don't own any nuts in that pitch). I have these two sets of Gorilla nuts I'd prefer to re-use that are already M14x1.5.
I contacted motorsport hardware and they didn't have any suggestions other than "use our open-end nuts." I also questioned them about the corrosion resistance of their stuff, since I've been bitten in the past with this (Apex Competition's "track" grade black-oxide studs are not all-season-ready and will rust; their silver/zinc coated stuff holds up fine though).
MH's answer about salt resistance was as follows (direct quote):
Originally Posted by MotorsportHardware
The black zinc on the studs is pretty durable. Should be similar to OEM but Salt and Sitting snow is very hard on them. They will not rust as easily as the Black oxide but salt and road chemicals will eat through anything this. Even the finish of your original wheel hardware will not last in that environment.
I'm not sure where they got the idea I'd be leaving my wheels "sitting in salt and snow."
      11-08-2017, 09:49 AM   #9
gsrbri
gsrbri's Avatar
560
Drives: F87 6MT
MSI racing studs through Turner Motorsport - https://www.turnermotorsport.com/p-3...SABEgKpxfD_BwE
      11-08-2017, 11:00 AM   #10
ZPrime
I INDIC8
ZPrime's Avatar
612
2018 BMW M2  [9.50]
I saw those, e-mailed Turner a day or two ago with length questions and asking about corrosion resistance, and have not gotten any response. Not exactly confidence-inspiring. They discuss using Manganese Phosphate as the primary coating -- manganese phosphate is porous, so itself does not directly stave off corrosion. You have to oil the coating, and the oil provides the water & salt resistance... but using lube on something designed to capture a nut and hold a wheel on seems kind of unwise to me.
I also think they will be too long to be used with my ~2" deep nuts... I'm starting to think this is a lost cause, which pisses me off since I have two sets of the damn things.
Anyone know roughly how thick an average wheel is, as far as how much stud length it eats up?
      11-08-2017, 11:02 AM   #11
CommitConfirm
475
Drives: The Bus
Why not just use the BMW parts from the M235i racing?
http://www.realoem.com/bmw/enUS/show...diagId=36_2018
      11-08-2017, 12:52 PM   #12
ZPrime
I INDIC8
ZPrime's Avatar
612
2018 BMW M2  [9.50]
Interesting...
Is the wheel-side of that threaded M14x1.25 though (like the hub-side)? I explicitly do not want that; I want a stud that is M14x1.5 thread pitch on the "outside," which allows for a much better nut selection. (There are very few M14x1.25 nut options on the market.)
Additionally, if it was designed for a pace car / racing application, there's a decent chance it isn't corrosion-resistant (the assumption is that the studs get replaced regularly by a maintenance/race team, so they give them temporary coatings rather than stuff designed to hold up to daily-usage).
      11-08-2017, 01:11 PM   #13
twin fed
Doc Brown
twin fed's Avatar
1176
In the "stud" world these are actually very short and can probably be used with longer closed ended lug nuts
      11-08-2017, 03:15 PM   #14
ZPrime
I INDIC8
ZPrime's Avatar
612
2018 BMW M2  [9.50]
By "these" do you mean the BMW ones? They did look short to me from the picture.
My concern is the thread pitch on them (which isn't documented but I'm guessing is 1.25 instead of 1.5), as well as corrosion resistance...
      11-08-2017, 03:56 PM   #15
CommitConfirm
475
Drives: The Bus
Why do you want 1.5 thread, what is wrong with 1.25?
      11-08-2017, 04:15 PM   #16
ZPrime
I INDIC8
ZPrime's Avatar
612
2018 BMW M2  [9.50]
Much easier to cross thread 1.25
Almost no options for different nuts in 1.25
I already own two sets of nuts in 1.5 that would work great for my needs
      11-09-2017, 07:42 AM   #17
twin fed
Doc Brown
twin fed's Avatar
1176
Sorry I did not specify, but I meant the ones from TireRack that I posted above that I am trying to sell.
The TPI ones seem to be extremely well made and I don't think that cross threading would be an issue. With the bullnose the initial threading of the nut to the stud is very smooth and engages nicely.
      11-13-2017, 12:47 PM   #18
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Don't use titanium if you do and one breaks you get to replace your wheel hub.
      11-13-2017, 08:51 PM   #19
ZPrime
I INDIC8
ZPrime's Avatar
612
2018 BMW M2  [9.50]
Why would you say that?
Titanium isn't especially hard, it can be drilled out. Only reason to use titanium is weight or corrosion resistance.
I've never seen a titanium screw-in stud though, only titanium nuts.
      11-14-2017, 10:16 AM   #20
CosmosMpower
2051
Nope they can't be drilled out
      11-14-2017, 07:33 PM   #21
ZPrime
I INDIC8
ZPrime's Avatar
612
2018 BMW M2  [9.50]
Standard titanium is not much harder than steel. It's a 6 on the mohs scale, steel is a 5.
You can drill out titanium, I don't know what you are talking about. You'd want a tungsten-carbide drill bit to do it, but it's certainly possible.
Completely moot point since I'm not looking for titanium anyway though.
      11-15-2017, 05:49 PM   #22
gsrbri
gsrbri's Avatar
560
Drives: F87 6MT
I'm delighted with the MSI studs/nuts. They do offer the 1.5 pitch threat for the business end. They are high strength steel and so are the nuts, but the nuts are coated. The dry lube on the studs - we shall see.
Are you going to DD the car through RE winter? The studs on my M4 made it through 3 winters w/very minimal corrosion.
I went with MSI for the M2, which is now a second track/street car that will never see winter.
m2
