BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding G30 - ASS Coding
      10-22-2017, 10:02 AM   #1
vkoprivica
19
Drives: 2018 BMW g30
G30 - ASS Coding
Hi All,
I am new to coding and wondering how can I code g30 auto start/stop option to remember last setting (off) that was set prior to locking the car, or to set auto start/stop option default value to be always off in comfort mode. Since this will be the first time to code g30, can you please let me know which esys software version is recommend to use as well as other files, and where to find ASS setting?
Thank you.
      11-06-2017, 05:58 AM   #2
Cooper777
Drives: F30 335
you needed coding ecu dme or dde
      11-06-2017, 07:16 AM   #3
vkoprivica
19
ecu dme
      11-27-2017, 08:32 PM   #4
vkoprivica
19
I was able to code stop/start to remember last setting. I was able to find an option TCM_MSA_MEMORY under:CAFD_00002742_000_105_003.ncd. Paramethers Wert should be set to Wert_01 and Werte=01.
      11-29-2017, 08:49 AM   #5
sor
sor's Avatar
3102
Drives: 2023 iX M60 Oxide
2023 BMW iX M60  [0.00]
Which version of ESYS did you end up needing for g30?
      12-02-2017, 02:18 PM   #6
vkoprivica
19
Sorry, it took me a while to make a video.
BMW G30 ASS Coding to Remember Last Setting
- E-Sys 3.27.1, PSdZData_v3.62.5_Lite
- During the coding enginee is OFF, ignition switch is ON, key fob is in the car.
You can find all info in here:
Appreciate 2
      12-03-2017, 07:48 AM   #7
Ryno 27
252
Drives: M5 Competition, X5 M50i
Default is to have it on? Can dealership change this?
      12-03-2017, 08:04 AM   #8
vkoprivica
19
They can if they want it to. Few years ago they did for my bmw f30.
      12-03-2017, 11:19 AM   #9
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
After 7/1 default is on in states. Dealership are no longer authorized to code memory.
      12-05-2017, 01:29 AM   #10
pemz
pemz's Avatar
Netherlands
26
Drives: BMW 320D F30 ... G30 soon
- Enginee is OFF, ignition switch is ON, key fob is in the car.
So I did the same this morning. But during coding the car turned itself off and got a service message in the screen to visit the nearest dealer. At the same time got all green from Esys. After restarting the car, message was gone and all seems well.
      12-05-2017, 02:25 AM   #11
Almaretto
Almaretto's Avatar
2374
You cannot program or code DME/DDE (engine ECU) while active/running. So, You must either have either not have external power source or left accessory mode running too long before attempting coding.
      12-05-2017, 02:28 AM   #12
pemz
pemz's Avatar
Netherlands
26
Ok, so leave the engine off and contact on. Gonna try again in a few.
EDIT:
It worked. Thanks again Almaretto, you're a big big help! vkoprivica too!
Next step is, enable start in ECO PRO mode... :-)
      12-05-2017, 09:37 AM   #13
Almaretto
Almaretto's Avatar
2374
EDIT:
      12-07-2017, 10:40 AM   #14
joe black
Drives: 2018 X3 M40i
ASS coding
The same thing happened to me two days ago. I thought I killed my 6 day old G01. Scared the hell out of me! But like yours, the car restarted OK with no apparent issue. My Esys did throw a big red error code and thus, did not disable ASS. I did successfully disable to OBD alarm, so that was good. When I get over my PTSD, I plan to try again. I have one question. In a prior G30 post, the following was posted:
TCM_MSA_MEMORY under:CAFD_00002742_000_105_003.ncd. Paramethers Wert should be set to Wert_00 and Werte=01.
Above, in this thread, it says:
I forgot what default was. Can you tell me which is correct or does it not matter?
Thanks!
      12-07-2017, 10:53 AM   #15
joe black
ASS coding
Also, to confirm:
"Engine is OFF, ignition switch is ON, key fob is in the car."
I just have to code this in the 15 minutes the car stays active in the above state.
Correct?
Thanks again.
      12-07-2017, 11:49 AM   #16
Almaretto
Almaretto's Avatar
2374
Thanks!
It matters and factory depends on region and firmware version.
      12-07-2017, 12:33 PM   #17
joe black
So then "Paramethers Wert should be set to Wert_01 and Werte=01." is the correct code to make memory active?
And am I correct about "Engine is OFF, ignition switch is ON, key fob is in the car."?
Thanks
      12-07-2017, 02:17 PM   #18
Almaretto
Almaretto's Avatar
2374
Thanks
You set werte or dropdown.
      12-10-2017, 09:30 AM   #19
joe black
G series coding
i successfully coded the memory for ASS and eliminated OBD alarm and 3 legal disclaimers. All good now. Thanks to vkoprivica; your video was very helpful!
      12-10-2017, 01:23 PM   #20
gizmonder
Belarus
Drives: G30 530i
I don't see DME ecu in Esys for my 530i G30. Also it's missing in ISTA. That's strange.
Is there some trick for G30? Can someone save and share 530i's SVT? I want to try CAFD injection.
      12-10-2017, 01:26 PM   #21
Almaretto
Almaretto's Avatar
2374
DME is engine ECU. You would have to have one present. You cannot use someone else's SVT.
      12-10-2017, 01:33 PM   #22
gizmonder
Belarus
Drives: G30 530i
There are 19 ECUs in Esys and ISTA. And there is no DME_BAC2 (and any DME at all).
I've tried to read data in diagnostic mode, with running engine, with just ignition on - same result - no DME.
UPD:
Screenshot attached
5post
