Door Locks Not Working With The Fob
10-20-2017, 11:23 PM | #1 |
60
Rep 158
Today when i tried to lock my car using the key fob there was no response. So i removed the key from the fob and done it manually.
1. I have checked the fuses as per the diagram related to the issue and all fuses are good, also double checked using a meter. 2. When inside the car and use the lock button on the dash it can lock and unlock the 4 doors no problem. 3. I have both FOB's for the car that i switch around to charge the battery and neither can active the locks. |
10-22-2017, 06:56 AM | #2 |
196
Rep 291
Is the car an e91?? (Touring)
If so, likely to be broken wires within the right hand wiring loom on the tailgate. Very common problem. You would need to cut open the rubber gaitor, repair the wires and then tape up the gaitor again to keep water out. |
10-23-2017, 07:31 AM | #3 | |
68
Rep 286
To the OP: if you can bear the doors trying to unlock, try and spray a little wd40 in all its orifices 1. The nipple bits that pop in and out top of the door inside as you lack and unlock 2. The latch itself that clamps on the door frame (you can get the WD40 red pipe in 3 different spots there 3. The actual door lock outside, some which are covered by plastic cover. Mine were starting to be noisy, a little slow and not synchronised. Much smoother and faster now. |
10-23-2017, 10:45 PM | #4 |
60
Rep 158
Gents i have now discovered something that was previously unknown to me.
I thought my Key Fob was the type that charges when placed in the dash slot. I have now discovered that it is fitted with a CR2032 battery, i have now fitted a new battery and all is back to normal. |
10-24-2017, 05:52 PM | #5 | |
68
Rep 286
