ZPOST
  TireRack
      05-19-2008, 12:01 PM   #1
dabo
Drives: Z4
Z4 Gas Cap Plastic Shroud removal
Greetings Gents!
Just bought my first Z4, and I think I'm going to like it. It's an '05, and has a small ding just below the gas lid. If I could remove the plastic shroud inside the lid, I believe I could push out the ding. I removed the size 15 tork screw, but there must be something else to remove before the plactic piece comes out. Any tips or suggestions would be much appreciated. Once I fix this ding, I'll be working on the bluetooth. Thanks in advance!
dabo,
Heideberg, Germany
      02-25-2011, 10:43 PM   #2
sullivan8
Drives: toyota corolla
hey, any updates on this? have you already been able to remove it? if not, can you maybe post a picture for us to see? i'm just curious what you're referring to.
________________________________
Gas Doors & Caps
      02-25-2011, 10:55 PM   #3
santov
santov's Avatar
63
Drives: 2007 Z4 3.0si White over Beige
Oh I just did this to straighten out my door, which was just a smidge off center.
There's one screw (T20) on the left side, then there's a grommet that centers the gas lock (a plastic pin). Remove both the screw and grommit and the whole door, hinge, and rubber boot wiggle out.
I can't remember if I could look down and see the inside of the fender. You could always remove the tire and fender liner and get in from the bottom.
Hope this helps!
Search this Thread:
Advanced Search
zpost
