Non-iDrive to EVO NBT iDrive Conversion Kit
10-13-2017, 12:49 PM | #1 |
19
Rep 103
Up for sale is a kit I bought from Bimmer Retrofit a while back to do a full non-iDrive to EVO NBT conversion in my E90. Unfortunately some life-related stuff happened and I just haven't been able to install it so I'm letting it go. This is something like $2500 in hardware, I'd like to get $1200 plus shipping (cost dependent on location) for it. Here's what it includes: - iDrive double scoop dashboard with airbag, in excellent condition with no scratches or marks. Swap your matching trim and accessories over, all E series are the same. - Center console CIC trim with dremeled hole for the touch controller - Standard eNBT EVO ID6 Retrofit Kit ($1899) FEATURES SUPPORTED · Video streaming from USB stick/USB hard drive (if USB/AUX in the armrest is available) · Video in Motion activation · Android screen mirroring · 6NR (BMW Apps) · Apple CarPlay · Sports display (real-time power and torque meters) INCLUDED WITH THE KIT 1 x NBT head unit updated with the latest firmware 1 x NBT EVO CID display, fully pre-assembled for your E9x for PNP installation (non-touch display) 1 x CID Video cable 1 x eNBT Retrofit Adapter 1 x Bluetooth antenna and cable 1 x WiFi antenna 1 x USB cable 1 x pre-wired LAN cable (PNP) 1 x Microphone cable 1 x Touch controller + PNP touch wiring 1 x GPS antenna (magmount, aftermarket) 1 x Installation instructions Additional required parts, purchased at added cost 1 x CIC faceplate 1 x CIC front panel Other Add-ons included 1 x touch controller ECU (for touch gesture support with eNBT) 1 x Microphone Some notes: - Coding will be required. All the parts should be there, but they'll have to be coded to your car - The touch controller space is dremeled out in the center console, but the controller is not physically secured in there. Not a big obstacle, but just to be clear that it's not mounted yet. - No MOST associated hardware, I don't have Logic7. - I'll include the Bimmer Retrofit installation instructions. To be clear however, I'm not able to provide technical support; this is parts only, other than their instructions you're on your own for installation. PICTURES Last edited by JoeRogan; 10-17-2017 at 09:53 AM.. |
10-14-2017, 12:58 AM | #2 | ||
395
Rep 662
10-14-2017, 03:18 PM | #4 |
19
Rep 103
Just FYI for everyone, box is about 58lbs and 60x24x22 inches, will ship from 01845 if you want to estimate shipping on your own. Based on the quotes I've been looking up for people it looks like ~$250-350 depending on distance (furthest being all the way across the country).
10-15-2017, 10:35 AM | #5 |
132
Rep 319
Drives: E90 335i, E70 35i, E83 3.0i
Tasty deal.
10-15-2017, 05:16 PM | #7 |
19
Rep 103
