10-06-2017, 07:29 AM | #1 |
1322
Rep 2,924
What do you recommend? I am thinking on going 10mm all around (or 12mm)with car lowered on H&R srpings?
Any issues for tracking/rubbing? Post pictures if possible. Thanks for your help.
BMW ///M Club Montreal
BMW ///M Club Montreal Facebook Page |
10-12-2017, 05:41 PM | #2 |
1322
Rep 2,924
Look what I got in the mail today...
Deutsches Blut82.00 |
10-13-2017, 11:02 AM | #3 |
Doc Brown
1176
Rep 2,174
I have the H&R springs and 10mm spacers and I rubbed at all four corners till I got an alignment and then now the only time I rub is on some dips on the front right wheel. To guarantee that you won't rub you should get front camber plates
Benzima1322.00 |
10-13-2017, 11:33 AM | #4 |
1322
Rep 2,924
Do you think it would rub without the 10mm spacers?
10-13-2017, 11:38 AM | #5 |
Doc Brown
1176
Rep 2,174
No, I don't think it will. you could always get 5mm spacers if you want to be 100% sure. But there are others that run 15mm spacers and H&R springs and have no issues. Each car is slightly different.
10-13-2017, 11:48 AM | #6 | |
1322
Rep 2,924
10-13-2017, 01:32 PM | #7 | |
1322
Rep 2,924
10-13-2017, 02:19 PM | #9 | |
101
Rep 211
Perfect looks and no rubbing ! |
Benzima1322.00 |
10-13-2017, 02:30 PM | #10 |
1322
Rep 2,924
Looks good! I will measure mine and share the results.
twin fed1175.50 |
10-16-2017, 06:07 PM | #11 |
325
Rep 240
I have the H&R's with 10 mm all around. No rubbing on the streets with stock. Went to COTA two weeks ago with 18" square setup. Found the rears rubbing, removed the rear spacers and almost no rubbing after that. I have 1.5 degrees of negative camber front and back. So, beware if you track it!
'02 E39 M5-Gone
'07 E60 M5-Gone '07 E64 M6 Cab-Gone '17 F87 MG M2-Gone '19 F87 SO M2C |
10-16-2017, 06:36 PM | #12 | |
1322
Rep 2,924
10-17-2017, 07:32 AM | #13 |
1322
Rep 2,924
Just measured the gap between fender and tire lip at stock height: 3.5in all around. Will post results once installed tomorrow.
10-19-2017, 12:02 PM | #14 |
1322
Rep 2,924
Drop was exactly as advertised by H&R: 0.8in all around. They might settle a bit more but I am very happy with the drop and how the car behaves. It will be ready for track next year.
10-19-2017, 01:33 PM | #15 |
1836
Rep 4,204
I am planning on doing H&R springs also...maybe HAS kit. Not sure yet and see how it looks with the stock wheels. The only worry with the M2 and spacers is the way the fender lip is not rolled all the way up. A friend cut a tire at VIR on a track day but I can't for the life of me remember what his set up was. I know he had 20in ZCP wheels
10-19-2017, 01:43 PM | #16 | |
1322
Rep 2,924
I am running 19in 437M wheels.
11-20-2017, 06:00 PM | #17 |
1836
Rep 4,204
I grabbed andrewc89's H&R springs
Benzima1322.00 AndrewC198910903.50 |
11-20-2017, 07:05 PM | #18 |
1322
Rep 2,924
11-20-2017, 08:04 PM | #19 |
281
Rep 399
Drives: 2017 BMW M2 6MT
'17 BMW M2 LBB 6MT MPE
'13 BMW 335i Estoril Blue - sold |
11-20-2017, 08:07 PM | #20 |
1322
Rep 2,924
Post installation
11-20-2017, 08:08 PM | #21 |
1322
Rep 2,924
Pre installation
11-20-2017, 09:20 PM | #22 |
281
Rep 399
Benzima1322.00 Thevintage19.00 |
