F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > 2013 F30 335i Front Brake Pad Question
proTUNING Freaks
      10-02-2017, 01:20 PM   #1
ChillVibeF30
17
Drives: Black 2013 BMW 335I
Hi all,
Could someone tell me how I can get my brake pads out from the caliper?(See photo below)? Do I need to punch the pins through on the two holes shown, thus releasing the pads? Also what are those "clips" highlighted in the red rectangle?
Ive change brakes on other vehicles before, but never on one with Brembo brakes.
Thanks,
Dennis
      10-05-2017, 05:08 AM   #2
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
Yes, use a punch to knock out the 2 pins from front of caliper, then grab the tabs you have highlighted & pull the pads out.
To install new pads, you will prolly have to use a caliper piston spreader tool to retract the pistons back in their bores to make room for new thicker pads
I use the Lisle tool which works great on our 4 piston calipers to retract all pistons at same time - with this tool you will never have to remove your calipers to replace pads - after pad removal this tool can fit in opening of caliper where pads where and it ratchets the pistons back very easily:
https://www.ecstuning.com/b-lisle-pa.../lis29100~lis/
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      10-05-2017, 09:43 AM   #3
Orion4
481
Drives: 2013 335i Sport Line Sedan
This spreader is also available at ToolDiscounter at about half the price: http://www.tooldiscounter.com/ItemDi...ookup=LIS29100
      10-08-2017, 08:44 PM   #4
GarlicBread
GarlicBread's Avatar
165
Drives: 17' M4 ZCP
the above posts are correct. Be careful when punching the pins out as the metal clip will go flying. The spreader is excellent and is a must for really any brake job.
      10-10-2017, 02:25 AM   #5
dreamspeed
dreamspeed's Avatar
262
Drives: 6MT
Ymmv but sometimes you can press the pistons back in with your fingers. Either by pressing the pads or the pistons directly
      10-18-2017, 11:05 AM   #6
ChillVibeF30
17
Thanks for the info, could i use a "C-Clamp" to push the pistons back, like i would with any other calipers?
      10-18-2017, 11:53 AM   #7
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
C clamp will not fit in the slot of the caliper housing in between the pads
On single piston calipers there is a cutout in the outer wall of caliper that allows straight on application of clamp between rear pad face and rear of caliper housing - no so on 4 piston caliper housings there is no access from front
On these pad spreaders the paddles can fit down in thru the slot in housing then ratchet back both front/rear pads at same time - even while the caliper is still bolted to car - so no need to remove caliper at all
      10-18-2017, 04:59 PM   #8
a803sgo
170
Drives: BMW 320D M-SPORT (F30)
I just use my hands to push the pads back, cap off from the reservoir obviously.
      10-24-2017, 09:01 AM   #9
ChillVibeF30
17
Wow, i see why that tool is essential!!
Let me run the steps back.
1. Knock out the top and bottom pins of the caliper.
2. Pull on the tabs, which should pull the existing pads out.
3. Use pad spreader tool to push pistons inside the caliper.
4. Install new pads, and reinsert the two pins into the calipers.
Sounds about right?
      10-24-2017, 01:21 PM   #10
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Sounds about right?
Yup - Bam! you're done
Don't forget to pump the brakes after replacing both sides - that will move the pads back against the rotor - so no surprise 1st time you hit the brakes & there is more travel than expected
      10-24-2017, 06:37 PM   #11
Bestodabest
37
Drives: 2014 435i Xdrive
Don't forget to clean and lubricate the abutments!
      08-26-2018, 08:14 PM   #12
DrPhant0m
14
Drives: '14 335xGT M, Estoril Blue
I've got a 2014 F34, and my 4yr of no-cost maintenance ran out just before I needed front brakes... So I'm doing the job myself for the first time on this car. (I've done brakes on all of my other cars, but they've all had single pistons and none of these infernal pins)
I had the Front Passenger wheel off today, and I could not get the pins out of the caliper. Granted, I didn't know about them ahead of time, and the sun was setting, so I tried to use a nail and a small screwdriver with a hammer with no luck. What size drift punch should I use to get these pins out?
Also, should I lube up the pin before putting it back into place?
Thanks!
      08-29-2018, 02:23 PM   #13
ChillVibeF30
17
Thanks!
Not sure what size pin you'll need. I just "winged" it and was able to get it out using a small screw driver and my hammer. As far a lubricating the pins, i just gave mine a good cleaning. I think anytime you go in to remove them, they can still be a pain IMO.
Good Luck!
13' F30 335i
F80 M3 Front End, VRSF Catless Downpipe, BootMod3 Stage 2 E30 OTS, ER Chargepipe, VRSF 5" FMIC, BMS Intake H&R Super Sport Springs, Fuel-it Stage 2 LPFP
      08-29-2018, 07:01 PM   #14
Busa1
Busa1's Avatar
No_Country
275
Drives: M4 and 435i xDrive M-Sport
Should you remove some brake fluid (an oz or 2) before you perform a brake job. Ive seen a video and the mechanic in it did this. It seems to be a fairly straight forward job. Thanks
      08-29-2018, 07:59 PM   #15
rak299
601
Drives: 2021 M3 6MT
You just need a small punch and a hammer to remove the pins. They come right out
      06-18-2019, 08:55 PM   #16
sschaffer27
Drives: F30 335i
Bringing this post back to life because I would also like to know what the silver tabs are on the brake pads.
I got some new pads in today and one of the tabs fell of on 2 pads and I’m curious if I should send them back for a return or just use them.
Any idea/suggestion?
      08-21-2019, 12:58 AM   #17
kosz888
kosz888's Avatar
10
Drives: E92 M3 6sp Manual
I asked my mechanic the same question yesterday, he said the tabs are to reduce noise and vibration. Can anyone confirm this?
f30post
