09-15-2017, 06:49 PM | #1 |
967
Rep 2,655
Hi Friends -
Anyone have a good method for removing rust on wheel hubs? I am super meticulous when it comes to my car. I will spend hours washing, polishing and waxing but these damn wheels kill the effort. My front wheels have some sort of caps that cover the hubs but my rears are bare and have rust on them. Anyone else have these covers on a 335? If so, where can I buy a set for the rear?
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Tune Stage 2 - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI
09-15-2017, 09:56 PM | #2 |
8264
Rep 16,111
The best way to remove rust is with a wire brush mounted on a drill. Then repaint the hub with caliper paint. This shows the process:
I don't paint the entire rotor surface as shown in the video. I make a cardboard shield that goes over most of the surface where the pads contact the rotor. You don't have to completely shield it, 90% will do, the pads will scrape away any excess paint in no time at all. |
kpgray333.00 |
09-16-2017, 02:42 AM | #3 | |
6659
Rep 15,858
Have the rears been changed to a cheaper one-piece at replacement time? |
SpenceRx243.00 |
09-16-2017, 06:23 AM | #4 | ||
967
Rep 2,655
09-16-2017, 07:39 AM | #5 | |
GasCompressor
333
Rep 564
2022 Porsche 911 Cabriolet Agate Grey/Black PDK 2019 440i M-Sport Smoke Topaz Metallic/Opel (Sold) 2014 335i M-Sport Black/Beige MPPK/MPE (Totaled) 2013 328i Sport xDrive Imperial Blue/Grey (Sold) |
09-16-2017, 09:23 AM | #6 |
203
Rep 943
Drives: 2012 328i Modern Line
Will aftermarket rotors (non-BBK) rust as well? Next time mine are in need of replacement I?d like to get get some that don?t.
:wave:
09-16-2017, 09:58 AM | #7 |
8264
Rep 16,111
All rotors are made of cast iron, so all rotors will rust unless the portion not contacted by the pads is coated with an impermeable paint or other coating.
09-16-2017, 10:07 AM | #8 |
203
Rep 943
I guess I am actually just looking for recommendations for quality front & rear standard discs. I had Zimmermann x-drilled rotors on my e36 for years and never had any issues but it doesn?t look like they offer them for f30?s.
:wave:
09-19-2017, 11:01 AM | #12 |
1062
Rep 1,876
Ohh gotcha! Just read on forums that it helps with it but I guess not long term. Thanks for the info!
Mine: BSM F30 335i M Sport
Hers: AW F30 328i M Sport |
09-19-2017, 01:06 PM | #13 |
65
Rep 240
09-19-2017, 01:49 PM | #14 |
Old guy
Rep 10
Drives: 2011 335i
I used the lazy mans method and did not remove the hubs. I used a wire brush wheel on my cordless drill to clean off the rust. Then using a folded paper towel rubbed in a very thin layer of Permatex 80078 Anti-Seize just on the hat part of the hub, taking care to not get any on the part the pads engage of course. A little anti seize goes a long way and the color closely matches the original silver paint of the hub. It also serves as a rust inhibitor and lasted about two years before I had to repeat the treatment. Probably spent less than ten minutes per wheel so it goes pretty fast.
