09-11-2017, 02:22 PM | #1 |
Big Turbo Boys N Girls
327
Rep 579
6 Speed Manual Trans + Diff Oil Recommendations
Hello,
I have not seen much talk about the oils people use for our cars so wanted to see if we can get a new one that is most recent started. I usually change my diff and trans oil every 30K and from previous experience I have used MTL for the 6 speeds or the D4ATF. As for the DIff since we do not have the LS I usually used 75w110 or 75-90 for added protection and Redline or Pentosin exclusively. What have you guys used for the 6 speed and how have your results/ shifts been? |
09-13-2017, 04:24 PM | #2 |
518
Rep 891
Just crossed this bridge with my car before I hit 60k. I replaced the box with RedLine MTL, and used the OE Diff fluid as it was recommended I do from my Indy shop. Immediately I noticed shifts were smoother after picking it up, but make no mistake, our n20 boxes tend to be pretty notchy. While it was and is a great improvement, don't expect it to make it perfect. I had originally purchased Redline gear oil for the diff per what I found on a DIY on here, but my indy shop called me and told me that it is not a direct replacement to the OE's weight and viscosity. I took the safe route and went with their recommendation, so YMMV.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
09-13-2017, 06:39 PM | #3 |
404
Rep 808
I went with royal purple transmission fluid and OEM diff fluid (got it in bulk from an indie shop). Shifts improved very slightly, I think the important thing is that you change it and any of the respected fluid brands should do just fine
