08-30-2017, 02:56 PM | #1 |
27
Rep 57
DIY brake pad change
Hi,
I'm attempting to change my brake pads on all 4 corners with Pagids rs29. I already found the F80 pad change film on youtube. Just curious if there are some things I missed. I bought a proper torque wrench, a 3 ton jack and jack stands. My plan: 1. Loosen lug nuts 2. Jack it up. Hand brake on. Remove wheels 3. Hammer out the 2 holding pins. Remove clip. 4. Use a wrench to push the pistons back in 5. Remove oem pads 6. Place pagids in. Pins and clip back on 7. Place wheels back on Things I'm not sure about. 1. Do I need to apply copper grease or something else? 2. Do I need to remove pad sensors and tie them up? 3. How long does it take to bed them in? 4. Did I miss something Appreciate the feedback |
08-30-2017, 04:05 PM | #2 |
Wheelsucker
199
Rep 1,280
I swapped PFC pads last week for a trackday and yes on 1-7. I would add #8. Torque wheel nuts. #9 Pump the brake pedal before starting the car. On the second set, I didn't do 1, I pulled the sensors and zip tied them, I completed about 10 stops to bed in the pads before the first session and then the first session completed the job. Brakes were awesome for the 2 days with no fade. This is also at VIR which has 2 high speed braking zones.
08-31-2017, 01:06 AM | #4 |
27
Rep 57
Thanks for the feedback.
What is the correct torque for the wheelnuts. My mechanic told me 130Nm. Where do I ziptie the sensors to safely? And does this give an error message on the idrive? What are the differences between front and rear, can I expect problems with the parking brake? Pretty new for me, don't want to take any risks :-) Last edited by M2 Belgium; 08-31-2017 at 01:17 AM.. |
08-31-2017, 08:36 AM | #6 | |
Wheelsucker
199
Rep 1,280
I am no expert but I have done this dozens of times with no issue. |
08-31-2017, 02:05 PM | #9 |
518
Rep 444
Drives: 2017 M2 6MT, 2022 X7 M50i
08-31-2017, 04:47 PM | #11 |
793
Rep 1,367
08-31-2017, 05:03 PM | #12 | |
475
Rep 549
Drives: The Bus
Garage List 2017 Ford Focus RS [0.00]
1971 Mk3 Austin Min ... [0.00] 2013 MINI R56 GP [0.00] 2013 MINI R55 Clubvan [0.00] |
McPurrs290.00 |
08-31-2017, 05:36 PM | #13 |
793
Rep 1,367
08-31-2017, 07:35 PM | #14 |
518
Rep 444
From the manual
08-31-2017, 11:58 PM | #16 |
518
Rep 444
owner's manual
View post on imgur.com |
09-01-2017, 12:45 PM | #17 |
27
Rep 57
Why would I kill the pad sensors on track?
Do they need replacing when they are activated when the track pads reach their limit? I will run them on the street in track season occasionally |
09-01-2017, 04:17 PM | #18 |
234
Rep 350
The sensors are wear items, when the pad is worn out and needs replacing you have to replace the sensor at the same time. So if you wear out the sensor with your track pads it will need replacing or iDrive will be telling you to replace the stock pads too.
When using track pads you should simply leave the sensor zip tied out of the way and then when you return to street pads then put the sensor back in. When you're at the track you should keep an eye on the pads yourself rather than relying on the sensors. |
09-02-2017, 12:12 PM | #20 | |
609
Rep 1,124
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
09-03-2017, 12:57 AM | #21 |
38
Rep 177
09-03-2017, 05:48 AM | #22 |
38
Rep 177
