08-29-2017, 08:04 AM | #1 |
BMW Lover
Rep 16
Remote Parking Retrofit
My 2017 G30 didn't come with remote control parking. Does anyone know if this feature can be retrofitted? I have all three driving assistance packages.
08-29-2017, 06:30 PM | #2 |
39
Rep 85
Drives: G30 540i
If you have 360 view cameras and PDC. You can have it coded but, you will need to purchase a display key.
08-30-2017, 08:00 AM | #3 |
BMW Lover
Rep 16
09-19-2017, 10:16 AM | #4 |
Rep 41
Drives: BMW X5 45e -20, 225xe -16
Hi,
My friend has all the above options including the display key, what is needed on top of that to enable remote parking? Local dealer had said that not possible.... Which I didn't believe as all the needed hw should be there. Br, Ville |
09-19-2017, 11:51 AM | #5 |
1113
Rep 2,070
The following options are needed for remote parking according to the G30 technical manuals (Driver Assistance Systems manual available in the sticky on the main G30 general chat forum):
• Steptronicsporttransmission(OE*2TB) • ComfortAccess(OE322) • BMWdisplaykey(OE3DS) • ParkingAssistantPlus(OE*5DN) • Professionalnavigationsystem(OE*609) Those options contain all of the required hardware, I didn't know comfort access was required but apparently the comfort access antenna is needed for the RC parking |
09-19-2017, 01:17 PM | #6 |
Rep 41
Yes, he has all of that so whats the next step?
09-19-2017, 01:52 PM | #7 |
1113
Rep 2,070
09-19-2017, 04:38 PM | #8 |
1113
Rep 2,070
I have just noticed - there is another antenna solely for RC parking mounted in the boot/trunk lid.
See part 4 here: http://www.realoem.com/bmw/enUS/show...diagId=65_2644 It appears to only be installed in cars with RC parking based on the wording on RealOEM. Therefore, you will not be able to simply code the feature -new hardware will be required. |
09-22-2017, 10:25 PM | #9 |
2374
Rep 8,364
08-30-2019, 07:07 AM | #10 | |
Rep 1
Hello everyone! I'am struggling with this 5DV option. I just need to order this antenna no.4 part 65209351015 ? or i need something more from hardware.. Thanks! |
09-07-2019, 07:53 AM | #11 |
1140
Rep 1,139
Assuming you have all the prerequisites, you would need the antenna, the wiring/connector (61119861132), and of course, the new display key remote with the Remote Parking button.
09-20-2020, 04:19 PM | #12 |
172
Rep 740
Just bringing up an old thread, so technically, I didnt purchase the g30 yet as the market is a bit low on inventory but just doing some research on the car in the mean time.
With that being said, looks like to do the retrofit, the additional hardware it needs are: aerial antenna in the rear bumper and remote control receiver. As far as wiring goes, they both go into the BDC. Again, this is just from viewing the document below. There could be more to it that I may have missed. https://www.newtis.info/tisv2/a/en/g...ems/1VnYq2TVR3
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
09-21-2020, 03:25 PM | #13 | |
1140
Rep 1,139
09-21-2020, 03:27 PM | #14 | |
172
Rep 740
09-21-2020, 03:55 PM | #15 |
441
Rep 891
There is no solution to aftermarket programming of a used Display key. Also if your car does not have a option for remote parking BMW will not issue you a Display key with the remote parking option.
01-30-2021, 01:58 PM | #16 | |
Rep 2
I have just taken delivery of my 2017 G31 530d xDrive today with all the prerequisites and would love to retrofit Remote Parking. |
07-08-2022, 01:18 PM | #20 |
Rep 6
My G30 came with a display key but…..
This display key does not have the park button on the right side. So for people that think they are nearly there cos they have the key, you may need a slightly different one. For images please look here: https://www.autoblog.com/2017/07/07/...x73EILGugwxDrK |
08-08-2023, 07:56 AM | #21 |
Rep 2
It seems that I have all the necessrry options preinstalled on my G30:
322-Comfort Access 2TE-Steptronic transmission with shift paddles 5DN-Parking Assistant Plus 3DS-Remote Display Key VO coding is not a problem for me. But my display key does not have a Remote Controlled Parking--Button on the side. What can I do to use it anyway ? How to activate Remote Controlled Parking-Menu in the display key? |
