All 3 the injectors switched off
08-18-2017, 06:16 AM | #1 |
Rep 37
Car went into limo mode, reduced power came about, cannot drive more than 10mph, and car has shut off in that state . The ignition coils are getting no power whether I switch them around between cylinders . 1 2 and 3 just appear to be dead all at once . The car runs super rough at idle . I changed the spark plugs , 02 sensor, and no love also. What reason why three of these cylinders will stop all at once? Can the HPFP do this or possibly DME gone bad ? Here's my faults
Szl can signal/ detection tank empty/ communication (sportsmode egs) is missing/ message error/ injection calibration Ignition cylinder 1 burn time too short/ building up of fuel pressure ekpforward stroke Faultcode: null Faultset 1: (appeared at: 139304.0km) engine status: 1.00 0-n Engine speed: 416.00 rpm engine temperature: 37.50 °C Voltage cl. 87: 10.87 V Faultcode: null Faultset 2: (appeared at: 139304.0km) engine status: 0.00 0-n Engine speed: 0.00 rpm engine temperature: 46.50 °C Voltage cl. 87: 11.98 V Faultcode: null Faultset 1: (appeared at: 139304.0km) Kuehlmitteltemperatur Kuehlerausgang: 30.75 °C engine status: 2.00 0-n engine temperature: 38.25 °C Voltage cl. 87: 11.48 V Faultcode: Fuel mixture control Faultset 1: (appeared at: 139304.0km) Balance throttle model (factor): 0.90 - number of revolutions: 704.00 rpm Relative load: 42.00 % Intake manifold pressure: 58.00 kPa Faultcode: Fuel pressure plausibility Faultset 1: (appeared at: 139304.0km) Average Bank 1: 17.97 % Average Bank 2: 3.52 % PWM signal of the quantity control valve: 26.17 % rail pressure: 50.28 hPa Faultcode: Misfire, cylinder 1: Injection is switched off Faultset 1: (appeared at: 139304.0km) Lambda integrator group 1: 33.59 % Load value for misfire detection: 67.19 % Engine speed: 512.00 rpm engine temperature: 49.50 °C Faultcode: Misfire, cylinder 3: injection is switched off Faultset 1: (appeared at: 139304.0km) Lambda integrator group 1: 33.59 % Load value for misfire detection: 67.19 % Engine speed: 512.00 rpm engine temperature: 49.50 °C Faultcode: Misfire, cylinder 2 injection is switched off Faultset 1: (appeared at: 139304.0km) Lambda integrator group 1: 33.59 % Load value for misfire detection: 67.19 % Engine speed: 512.00 rpm engine temperature: 49.50 °C Faultcode: null Faultset 1: (appeared at: 139304.0km) Spark duration cylinder 1: 0.00 ms Kuehlmitteltemperatur OBD: 50.00 °C Engine speed: 672.00 rpm Voltage cl. 87: 13.41 V Faultcode: Misfire, a plurality of cylinders: injection is switched off Faultset 1: (appeared at: 139304.0km) rail pressure: 5.44 hPa Voltage cl. 87: 13.41 V ambient temperature: 24.00 °C Counters recognition bad road: 0.00 - Faultcode: null Faultset 1: (appeared at: 139304.0km) Spark duration cylinder 4: 0.00 ms Kuehlmitteltemperatur OBD: 45.00 °C Engine speed: 608.00 rpm Voltage cl. 87: 13.91 V Faultcode: null Faultset 1: (appeared at: 139304.0km) Spark duration cylinder 2: 0.00 ms Kuehlmitteltemperatur OBD: 45.00 °C Engine speed: 864.00 rpm |
08-18-2017, 06:45 AM | #3 |
58
Rep 665
The first thing I'd check are the brown ground wires on coil harness. They terminate on top of two of the valve cover bolts and can break off pretty easily, especially during a valve cover gasket replacement. Very easy to check and simple to fix.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
08-19-2017, 01:10 PM | #6 |
Rep 37
So the mosfets are good! Fuel pumps turns on and car turns over roughly! Can someone explain to me how to test the ground wires on the coil ?? Set it to DC, with car power on , put the negative on the bolt on the ground and the positive where?
08-19-2017, 03:22 PM | #7 |
58
Rep 665
Just make sure they are attached to the lugs and none of the wires or lugs are broken. All of the wires in the harness are small and aren't that hard to damage.
10-19-2017, 02:53 AM | #8 |
Rep 37
power supply on the DME went bad and was unfixable. Had the DME replaced and car ran better. I also had leaking injectors, which fixed this while issue.
10-19-2017, 08:00 AM | #9 |
2341
Rep 3,541
