E92 auto dimming mirror
08-02-2017, 07:50 AM | #2 |
622
Rep 3,198
Drives: E92 325i MSport Coupe
The mirror glass will have a small (5mm diamter) circular lens in the top centre of the mirror that detects headlights of cars behind you and activates the dipping mechanism.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
08-02-2017, 08:34 AM | #3 |
243
Rep 2,026
08-02-2017, 09:52 AM | #4 | |
165
Rep 1,059
Does this mean that I have auto dimming side mirrors too? |
08-02-2017, 10:00 AM | #5 | |
165
Rep 1,059
here is the list of options from free vin check: |
08-02-2017, 10:25 AM | #6 |
622
Rep 3,198
I've never heard of autodimming side mirrors. Don't think it would work. The interior mirrors uses the extra layer of glass as the 'mirror' when dipped. The side mirrors are one piece, so if the mirror 'dipped' you'd loose all rearward vision...
08-02-2017, 01:04 PM | #7 |
5488
Rep 5,424
Drives: Beige G31 40ix m sport
The autodim rear & door mirrors are electro-chromatic. They have a gel between two pieces of glass & the gel reacts to a electrical charge
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle Last edited by Chappers 71; 08-02-2017 at 03:09 PM.. |
08-02-2017, 01:40 PM | #9 |
5488
Rep 5,424
I thought I just did but to clarify, yes they do I have them on my e92 35i
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle Last edited by Chappers 71; 08-02-2017 at 01:45 PM.. |
08-02-2017, 02:19 PM | #10 |
886
Rep 9,097
You have following options;
1- BMW without any dip option (so inner mirror does not dim) 2- Inner mirror dim (as mentioned above that there is small circular thing) 3- Option 2+ folding and auto dip passenger mirror 4- Option 3 and auto dimming side mirror To check option 4, you find the small rectangular box on back right side of central mirror. This rectangular box is facing forward. Put you finger on it so it get the impression that its dark outside. Now turn on the flash light / torch on your phone and take it close to the small circular thing (which is facing toward you and it mimics that there is a car behind you with lights on). Your central mirror will auto dim and if your exterior mirrors are one with auto-dimming option, they will become dark as well. HTH.
08-02-2017, 02:32 PM | #11 | |
165
Rep 1,059
08-04-2017, 02:57 AM | #12 |
96
Rep 828
you can tell if your side mirrors are auto dimming - they have a second layer of material on them that doesn't quite fit the entire mirror.
08-04-2017, 04:32 AM | #13 |
165
Rep 1,059
08-04-2017, 05:01 AM | #15 |
165
Rep 1,059
08-04-2017, 07:28 AM | #16 |
243
Rep 2,026
08-18-2017, 10:46 AM | #18 |
283
Rep 2,343
I'm sure I have the auto dimming rear view but I've never noticed it work. I will have to try Makkan's test above.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
09-02-2017, 07:24 AM | #20 |
Rep 32
https://youtu.be/waP8KpA13nM
Auto dim mirrors on my e91. Car came with option 3 noted above, so auto dim rear view mirror (car has factory tinted rear windows and works fine) with powerfold side mirrors and auto dip passenger mirror. Had to code the option for interior AND exterior auto dim mirrors and add it to the vehicle order. Works great, very cool feature that I didn't even know I needed but now I have it will always want it. Last edited by bsmotorsport; 09-02-2017 at 07:33 AM.. |
