08-01-2017, 06:07 PM | #1 |
271
Rep 740
Weird Starting Issue*HELP*!
Hello F30 crowd.
I have this weird starting issue where the car tries to engage, but just goes up to ready and then drops. It makes the appropriate noises as if it going to try to engage, but the starter does not engage. This happens randomly and usually at the second press of the Starter Button the car fires right up. Today the car would not start after a few short trips and it gave me the malfunction indication for ignition, but after a few tries the car fired up. Took it home and then she would fire again and again for like 10 times and then the problem came back as it usually does. So the problem is existing and I am not sure what it could be. I will check the system voltage on the hidden menu and see if its within specs. History: The original Battery was replaced in Sept 2014. So this one has been there for nearly three years. I have a CTEK MUS4.3 Test and Charge unit and it states the battery is good, but I am not 100% sure. I am leaning towards a possible bad battery cell, but given that its three years old I am not sure. If it is the battery, what do you guys recommend BMW for 250 or another 92AH AGM from another source? |
08-02-2017, 02:30 PM | #2 | |
481
Rep 1,572
08-03-2017, 10:15 AM | #3 | |
271
Rep 740
I was wondering if anyone had similar issues. Today I tested the battery with the voltmeter and the CTEK and it was low (I guess its not holding charge, maybe a bad cell). That could be the reason, but I will keep trouble shooting. |
08-11-2017, 04:32 PM | #4 |
271
Rep 740
Update...
Tried to diagnose some more. I finally got Diagnosis software in the laptop so I will try to pull some codes. So far the battery its not the problem I spent a few days troubleshooting that. |
08-16-2017, 12:07 PM | #5 | |
200
Rep 536
Drives: 2013 335xi Alpine White
The car does all kinds of things when you unlock the car that drain battery power, such as priming the fuel pump and opening vents and such. |
