AC not blowing cold air. Compressor out?
08-01-2017, 03:58 PM | #1 |
Rep 89
Hey everyone,
As of this morning, my '09 E92 AC no longer blows cold air. (worked fine last night). Ambient air on max cold, but can adjust to hot air (i.e. max heater). The up/forward/down vent settings work. Just no cold air. I did some research, and there are three common causes I've seen. 1.) Schraeder valve 2.) Evaporator 3.) Compressor Before I take it in to the dealer to have if drained/recharged/dyed, how do I check if the compressor actually engages? The recharge and diagnostic will cost $230, whereas an aftermarket compressor is $500. I can replace the compressor myself, take the $230 diagnostic savings to apply to recharge after. What other troubleshooting can I do? I will check the fuse too. I appreciate the views and replies. Thanks. |
08-01-2017, 04:23 PM | #2 |
232
Rep 723
check youtube chrisfix its a simple diy. even if it doesnt solve your prob a 100% youll lnow2 whats wrong.
2007 335i E92 MT | MFactory LSD | Diff Brace | MHD/Wedge Tuned| BL Coils | Stg2 lpfp BoostConcepts | VRSF DPs | VRSF 7" HD FMIC | DCI | VRSF CP | BMW SSK | Billstein PSS Coilovers | M3 Control Arms | Whiteline Rear SF Inserts | SS brake lines | Z4 35is Rotors | Hawk 5.0 pads | M219s + PSS | PE Mod -SOLD
2016 M4 F82 MT |
wepio3.50 Antetokounmpo1551.50 |
08-01-2017, 04:51 PM | #3 |
Rep 89
Thank you! Very helpful. Seems you should be able to see compressor plate/wheel spin IF the clutch engages properly (and assuming my belt is actually spinning too). That's what I asked the dealer to do, take a moment just to see if the compressor is functioning and they gave a canned response of needing to take the car in.
08-01-2017, 06:31 PM | #4 |
58
Rep 665
90% chance it's just a leak. The compressor won't engage if the pressure is too low so don't assume the compressor suddenly went bad even if it's not engaging. Get a cheap $30 recharge kit with a gauge, preferably one with a dye or buy a can of A/C dye. If the system is low, charge it up, run it for a while, and then use a black light to located the leak. If it was fine one day and stopped working the next, the leak will probably be pretty easy to detect. Hopefully it's not in the evaporator because replacing it is a nightmare and very expensive.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
wepio3.50 |
08-01-2017, 06:55 PM | #5 | |
Rep 89
Would the car throw a code if I unplug the compressor housing, and try to manually engage the compressor with a 12 volt source? I don't want to eff anything up further though. |
08-02-2017, 06:08 PM | #7 | |
Rep 89
How often in these cases is it the evaporator? I'm definitely not shelling out $3,500 to fix this, so if something can DIY, maybe keep the car, or just sell it. |
08-03-2017, 09:31 AM | #8 | |
203
Rep 288
I'm just glad mine is an inexpensive fix. |
08-03-2017, 09:55 AM | #9 |
181
Rep 1,681
Few years back, I had a leak in the condenser as well. It had grown so big that as soon as I put dye in the system it lit up like a Christmas tree. My issue was that a bracket for the AR Design oil cooler was touching the condenser. Replaced the condenser and moved the bracket, no more issues.
08-03-2017, 10:04 AM | #10 | |
203
Rep 288
Did you replace the condenser on your own? If so, do you remember adding pag oil? If so, how many ounces? |
08-03-2017, 10:35 AM | #11 |
181
Rep 1,681
I did replace it on my own. I also did add the pag oil. I don't recall how much I added. I remember I did a lot of online searches and that's where I got the amount form. It wasn't a lot - it's hard to determine because most of the oil is in the compressor. Hard to figure how much gets removed when you apply vacuum to the system. But this was 4 years ago and the car still blows ice cold air to this day so it's not too delicate.
08-04-2017, 04:29 AM | #12 |
187
Rep 589
Two things to mention:
The E90 uses a clutchless compressor unlike most other cars. On a normal clutch-ed system the compressor clutch will engage or disengage if you turn the AC on or off, and it will stay disengaged if the system pressure is too low. On the E90 the compressor pulley is always spinning, but the ECU adjusts a plate inside the compressor to turn the compressor on/off. So unlike most other cars, the pulley will still be spinning even if the pressure is low. However if the system was working fine the other day, it's not likely that it's a leak. Did you notice any degraded performance beforehand? Usually with a leak it will slowly get warmer until it stops working. If it stopped suddenly then there's a good chance it's something else. |
08-08-2017, 10:58 AM | #13 | |
Rep 89
Thanks for the reply. I feel like the AC was pretty cold the day before it quit, but I also live in the south, where it's hot and humid all the time. So, what i perceived to be cold may be temperature variance between the awful mugginess of the south and anything that's colder air. It could have degraded over a few days due to a new leak, and never noticed, because i usually have max ac and windows down a bit. In any case, it's with the shop now. Just gotta see what it is. Hopefully not the infamous evaporator. Last edited by wepio; 08-08-2017 at 01:30 PM.. |
08-08-2017, 02:24 PM | #14 | ||
203
Rep 288
08-08-2017, 02:36 PM | #15 |
Rep 89
I'm not sure yet. Just got the call, haven't picked up the car yet. I can ask what they did to troubleshoot that component since it's "hidden", right?
What questions should I be asking to see if they've exhausted all options? |
08-08-2017, 03:15 PM | #16 | |
203
Rep 288
I would ask how were they able to determine it was the evaporator, because it's really up there hidden inside the dash. Dye test? Refrigerant sniff detector? Vacuum test? Details of said test(s) performed?
Reason I would raise these questions is based on what you mentioned in your original post.... Quote:
08-08-2017, 05:07 PM | #17 | |
Rep 89
"AC performance and leak test. AC system completely empty, pulled vacuum, failed leak test. Charged to 1.30 lb. Compressor OK, pressure are in spec. major leak detected at evaporator core. Recovered freon from system due to major leak. Recommend replacing evap. core." I asked how they diagnosed it was evaporator, and they said they used a halogen leak detector. Repair quote: $2,700 + tax. |
08-08-2017, 05:35 PM | #18 |
203
Rep 288
You can do this on your own if you're up for the tasks and have the tools.
Removal of the dash is not difficult, it's just time consuming. When I was looking for my a/c leaking, I was prepared to rip apart the dash because I did not want to dish out 3.5k for the dealer to do the evap. |
wepio3.50 |
08-08-2017, 05:52 PM | #19 |
Rep 89
Holy... Wow. That looks daunting. I'd be terrified I couldn't get it back together. I'll have to study that in more detail later. Thanks for the link!
08-09-2017, 05:28 PM | #21 |
4080
Rep 3,207
08-10-2017, 11:05 AM | #22 |
Rep 89
Then i'm just glad i got a good 8 years out of the car before it did! Sadly, still may be the end of this run with this car.
