2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB 2014 BMW m235i F22 automatic transmission oil leak
      07-29-2017, 05:24 AM   #1
KAY-OS
KAY-OS's Avatar
124
Drives: BMW m235i F22
Has anyone here experienced automatic transmission oil leak?
The dealer noticed the transmission oil pan was leaking small amount of oil. Dealer 'fixed' it under warrantee (not sure what they did to it). However, the leaking persisted (at the rear of the transmission oil pan).
Few weeks ago, brought it to a shop and changed the transmission oil pan with new gaskets and oil. However, oil leak persisted.
Any idea what's the cause? Is this a common issue with the ZF auto transmission? What's the next step in fixing this oil leak?
Thanks everyone.
      08-04-2017, 03:54 PM   #2
MarcoZandrini
444
Drives: 2018 M240i
THe tech needs to scrub the tranny in the vicinity of the leak, and then drive the car. This will help pinpoint the leak location. No, it's not common. ZF makes high quality trannies.
      08-04-2017, 04:23 PM   #3
Questofthetune
Questofthetune's Avatar
446
Drives: 13 GT50014 AW M235i(sold)
2014 BMW 235i  [0.00]
I think my 2014 actually had a leak fixed while it was in the shop as well- I gotta look in my service paperwork.
      08-04-2017, 04:42 PM   #4
3rdcoast228i
225
Drives: 2016 228i Msport
Sounds like it could actually be the output shaft seal that's leaking. The oil is running down to the pan making it look like it's the pan leaking. As suggested above, the tech needs to clean everything up and see where it's coming from.
      10-17-2017, 07:42 AM   #5
KAY-OS
KAY-OS's Avatar
124
Hi guys. Thanks for the reply. Brought the car to another shop, seems like the leak was between the transmission oil pan and the transmission. Guys at the shop applied some sealant rubber and installed a new transmission oil pan kit. Will bring it to the shop in a few weeks to see if this will cure the leak. Finger's crossed!
      03-31-2018, 10:50 PM   #6
Taunto
Car Enthusiast
Taunto's Avatar
282
Drives: 2016 BMW M235 X-drive
have seen the Oil pans leak from time to time. BMW has also had issues with Poures transmission cases where the oil physically sweats through the aluminum - i know it sounds ridiculous but i have seen it before.
2016 M235 - Melbourne Red
2005 BMW M3 - Sold
Licensed Automotive technician for BMW Regina
      04-01-2018, 11:21 AM   #7
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
just use "thicker" oil
Taunto281.50
      05-31-2019, 10:41 PM   #8
Duker
Duker's Avatar
Drives: 15 M235i X-Drive
My 15 M235i had a leaky pan and the lines to the cooler leaked as well. This was taking care of under the warranty when it had about 15/20k on it .... 178k now and haven't had a trans leak since ... have some other serious problems goin on, but no trans leak lol
      06-05-2019, 09:05 AM   #9
aturk
42
Drives: 2014 BMW M235i
178k? Impressive.
What other issues?
2014 M235i
      06-06-2019, 10:23 PM   #10
Duker
Duker's Avatar
I've got P00BC and P112E codes rearing their ugly heads. Also a P1290 wastegate code. Thinking my wastegate solenoid might be stuck . Runs like crap, won't idle, numerous misfires. If I explained all the weird symptoms it gives me, you'd swear I was absolutely crazy ... it's been amazing to me so I can't complain about having these issues. Bout it with 13k on it almost 2 years ago ..... so it's been good to me with all those miles racked up so quick ...
2addicts
