BMW 5-Series (G30) Forum DIY Discussions / Guides / Instructions IND | Painted Front Reflector Install Guide
      07-24-2017, 03:04 PM   #1
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
Painted reflectors are among the first additions made by any owner of a modern BMW. The unsightly orange reflectors installed in cars bound for North America instantly break the smooth lines of BMW bumpers.
IND provides painted reflectors as a cost effective solution relative to the purchase of a OEM European bumper. We start the process using the OE BMW reflectors for a factory fit, and the same paint process we would use to spray an entire car. Each reflector is sanded, prepped for paint, primed, then painted. We ensure that all lettering on the face of the reflector is completely removed providing the same finish as your factory bumper.
Many enthusiasts enjoy installing their own painted reflectors, so we’ve created this installation DIY to help.
Tools needed:
• 8mm socket and ratchet
• Adhesive remover or cleaning solvent
• Nylon prybar (optional)
Step 1:
First, turn the steering wheel to full lock, in any direction. This will expose the fender liner.
Step 2:
With the fender liner exposed, begin removing the 8mm screw closest to the ground near the reflector.
Step 3:
Once the fender liner screw is removed you will have full access to the back of the bumper cover. Using your hands or a nylon prybar pull the edge of the reflector from the bumper cover. This may take some work to remove, but the leverage applied by a nylon prybar makes the job much easier.
Step 4:
After the reflector is removed from the bumper cover take a cloth and some adhesive remover or solvent and remove the excess adhesive.
Step 5:
Now that the surface is clean remove the adhesive cover on the painted reflector and push reflector in place. Make sure to apply even pressure around all edges.
Step 6:
With the reflector installed it is time to put everything back together. Place the fender liner back into position and secure it to the bumper with the 8mm screw.
We've depicted the procedure in the images below. The images mirror the order of the steps above.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      07-26-2017, 01:27 PM   #2
G30
36
Drives: G30 540i xdrive
Thanks for the DIY! I've had these sitting in my room for the longest.
Appreciate 2
      06-26-2018, 07:35 PM   #3
sebash
sebash's Avatar
17
Drives: 2021 Bernina Grey 540i M Sport
thanks for the DIY. just did this. the only thing i did in addition was i had a razor blade on hand which helped separate that really strong adhesive from the car.
      06-27-2018, 09:54 AM   #4
IND-Distribution
BMW obsessed
9587
Nice! Yeah that is easily the most cumbersome part of the DIY, especially if there's lots that didn't come out with the reflector after extraction, haha.
      06-27-2018, 03:03 PM   #5
r33_RGSport
General
r33_RGSport's Avatar
12968
Drives: G09 XM, G05 X5 40, 991.2 T
Another pointer. Don't wait to long for this mod if possible, the old double sided tape getting harder to remove.
It will break in small pieces.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      11-20-2018, 05:56 PM   #6
Dobie Dog
Dobie Dog's Avatar
739
Drives: 2021 F97 X3M Comp
I just replaced my front and rear reflectors with IND paint matched reflectors. Easy install, very clean look. Thanks IND!
Life is short...Drive fast
Appreciate 2
      11-21-2018, 06:04 PM   #7
Mach550
Mach550's Avatar
472
Drives: 2019 M550i
2019 BMW M550i  [8.00]
When are you getting mediterranean blue for the center grill/front camera part?
      11-24-2018, 10:58 AM   #8
IND-Distribution
BMW obsessed
9587
Just added Mediterranean Blue to the listing.
https://ind-distribution.com/product?sku=IND-G30-CTRIM
      11-25-2018, 12:25 AM   #9
HomeIn2
HomeIn2's Avatar
326
Drives: 2020 X5 M50i
Any plans to also add Dark Graphite Metallic?...for the center grill/front camera part
      11-25-2018, 12:49 PM   #10
IND-Distribution
BMW obsessed
9587
It is now listed on the website.
      12-16-2018, 09:37 PM   #11
Bymep
Bymep's Avatar
132
Drives: 2019 M550i; sold 2003 330Ci
2019 BMW M550i  [0.00]
Will you be posting a DIY for swapping in a painted center grille/front camera part? Interested in replacing this as well as the reflectors. Thanks
r33_RGSport12967.50
      12-16-2018, 10:22 PM   #12
HomeIn2
HomeIn2's Avatar
326
Here you go https://g30.bimmerpost.com/forums/sh....php?t=1409557
Appreciate 2
Bymep132.00
r33_RGSport12967.50
      01-17-2019, 03:43 AM   #13
MXNSITH
199
Drives: 2020 M5C, 2019 i3 REX, 2010 Z4
Any specific solvent or adhesive remover recommended?
2020 M5 Comp
2019 i3 Rex
2010 Z4 35i
      01-17-2019, 11:16 AM   #14
r33_RGSport
General
12968
Your car is 2019, the original double sided tape will remove very easy.
But if you insist, use GooGone then wipe it down again with rubbing alcohol.
MXNSITH198.50
      01-17-2019, 11:55 AM   #15
M550iG30GUY
M550iG30GUY's Avatar
37
Drives: 2019 BMW M550i
Do you offer a rear tow book cover in matte black. I ordered my car with the m performance diffuser and they just slapped the gray cover that the car came with from the factory.
      01-17-2019, 09:40 PM   #16
Bimmertrashjr
119
Drives: 2012 535i
Tell the dealer to get the matching cover. If he/she doesn't get it done speak to his GSM. There is no reason they shouldn't provide it. That was a b.s move on their part..
      01-18-2019, 08:17 AM   #17
r33_RGSport
General
12968
Tow hook cover is sold separately by BMW.
And I believe it came in grey primer, not matte black.
      01-18-2019, 12:29 PM   #18
M550iG30GUY
37
I know. I thought it came matte black so I paid for one from bmw. Now I have two tow hook covers and neither are matte black FML
      01-18-2019, 12:54 PM   #19
r33_RGSport
General
12968
Ouch.
Rattle can in Matte Black should fix it. It is small enough, wouldn't be hard to paint.
      01-18-2019, 12:56 PM   #20
M550iG30GUY
37
Ouch.
Rattle?
      01-18-2019, 01:09 PM   #21
r33_RGSport
General
12968
Rattle?
spray can from AutoZone or Pep Boys.
      01-18-2019, 01:13 PM   #22
M550iG30GUY
37
Rattle?
Something like this?
5post
