F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > AUSTRALIA > Apps in Motion Australia
Extreme Powerhouse
      07-13-2017, 02:13 PM   #1
JakOG
44
Drives: 2011 535i MSport
Hey Guys,
In Australia, BMW apps doesn't work in motion, making it useless.
In the US it does work in motion.
I think its also a problem in Hong Kong too.
Their is almost no information on this problem anywhere on the forums
From all I have found so far, the CIC and Combox hardware and software is identical to the US.
Just some different regional settings.
Given this, you would think it would just be a setting that could be changed.
The only other information I have come across is that a settings/XML file is written to the Hard Drive in the vehicle which stops this working.
From what I can gather, you can get access to the hard drive in a CIC vehicle over telnet
Any ideas?
      07-13-2017, 06:03 PM   #2
DOCTOR.Y
Eric_Y
Australia
103
Drives: 2016 340i, 2010 E92 M3
2016 bmw m3 f80  [0.00]
2010 M3 E92  [0.00]
My earlier CIC works (2012 E92 335) but my NBT does not work. I have tried to use 'service in motion' from binmertech to activate BMW apps but it doesn't unlock it.
I do want this feature but seems not many people ask about this
      07-13-2017, 10:22 PM   #3
JakOG
44
What version of I drive to you have in the E92 and your NBT car?
      07-13-2017, 10:38 PM   #4
DOCTOR.Y
Eric_Y
Australia
103
2010 M3 E92  [0.00]
Versions? My E92 is MY2012 and F30 is MY16.
      07-15-2017, 09:50 AM   #5
JakOG
44
Just trying to determine if thier is any difference in CIC for a 2010 MY11
and CIC for E92 MY12
      07-16-2017, 05:14 PM   #6
JakOG
44
Yes Bimmertech don't seem to know this one.
Are you talking just Apps or connected drive on your E92?
      07-17-2017, 12:51 AM   #7
DOCTOR.Y
Eric_Y
Australia
103
2010 M3 E92  [0.00]
I'm talking about BMW apps only. Connected drive is a general term that contains many services, BMW apps is one of them. For E9X CIC only some services can be activated, so yeah I'm taking about BMW apps. After activating bmw apps, my E92 can run BMW apps no matter car is in motion or static. When it comes to F30, once D is engaged or hand brake is released, BMW apps becomes inactivate.
Bimmertech has no idea about this because US NBT doesn't have this restriction. What I'm surprising is, with so many Australian F chassis owners here, there seems no one care about this feature....
      07-18-2017, 06:08 PM   #8
ontheway
15
Drives: F31 MSport 328i
The only reason I don't care is that I didn't bother using them give the restrictions and don't know what I am missing.
My research indicates the same as yours. There was some indication that you can update the XML file via a map of firmware update but no positive confirmation that it has been done on NBT - presumably encrypted.
DOCTOR.Y102.50
      07-20-2017, 06:58 AM   #9
JakOG
44
Interesting that it works on a 2012 E92 with CIC
And yet all the F10's with CIC it doesn't.
These are the questions I think we need answers to.
Is the US hardware that it works on identical to the AUS hardware.
Is CIC Combox and NBT identical in AUS?
I'll see if I can check some part numbers just to make sure.
Is the Apps software identical in US and AUS?
Don't know how to check this
What is this XML settings file?
I may remove my hard drive and find a way to read the file system
How to write to the encrypted XML file in NBT?
Don't know this one either
What is the difference between a 2012 E92 with CIC and a 2012 F10 with CIC?
If anyone else has any input feel free to add
      07-20-2017, 07:10 AM   #10
JakOG
44
Looks like hard drive has a QNX file system
Should be able to get it out and read it with some linux distro.
      07-23-2017, 07:46 AM   #11
ontheway
15
Long thread but about 2/3 along it outlines how to mount the NBT drive on QNX and they have worked out how to derive the HDD HW level password: http://www.bimmerfest.com/forums/arc.../t-787230.html
      07-27-2017, 08:18 PM   #12
JakOG
44
I've seen that thread. Very interesting
I'm going to get the hard drive out of my car soon and take a look at the contents.
      10-04-2017, 06:15 PM   #13
sj03
Australia
Drives: M4 Competition
Bump.
I also have this problem with "BMW Apps" not working in motion and would like to know if there's a work around.
      04-01-2018, 06:35 AM   #14
sj03
Australia
Update... I've got the ConnectedDrive apps to work without having to have the hand-brake on. So it's possible to view them while stationary at a set of Lights, for example.
I used the Bimmercode app to change the Coding for some of the VideoInMotion related Codes. I've attached the Coding Guide that I found on another post in the Forum, that has the relevant Codes listed under "VideoInMotion...".
      04-03-2018, 12:10 AM   #15
Bambazonke
Bambazonke's Avatar
Australia
210
Drives: 2017 X5 & 2020 X5
  [0.00]
Apps in motion
I have just had VIM >63kmph enabled on my X3 with idrive 5 and asked the supplier about enabling Apps in motion this was his response
"***** .bin for Video-In-Motion(VIM) unlocks all video based features (CarPlay, Screen Mirroring, USB Video, and DVD) but no Text Messages, Emails nor Connected Drive App Services (e.g. News Weather) to work in Motion. I guess the things you are referring to are via Connected Drive Services. These are controlled via provisioning of car, and for older NBT, this can be manipulated, but for NBT2, the file is digitally signed by BMW AG, so not possible to edit."
I did post on the forum a couple of weeks ago the iOS Spotify app works in motion but not the Android version! The BMW Calendar and Connected Drive Apps also now work when the vehicle is in motion.
I was down in Brisbane over the long weekend and hired a Hyundai i30 that had factory Nav Carplay and Android Auto fitted. Rather annoyed to see Spotify & TuneIn radio apps work with no issue whilst the vehicle was in motion. BMW Australia need to see what all the other manufacturers are legally? enabling on their Australian spec vehicles before they disable these functions
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive
      04-03-2018, 06:47 AM   #16
fuzzyboat9239
Drives: MY2017 440i GC
If this is true, this is an awesome breakthrough! Great find!
      07-31-2020, 08:16 AM   #17
uadissa
Australia
Drives: X3 G01 20D M-Sport
Today I was able to fix a disappearing Spotify app on connected drive by simply going back to an older version on my Android phone. This suggests that the Spotify Android app itself, might be the culprit for the motion lock issue. Especially Spotify being available in motion for iPhone users for years.
I suggest giving the Spotify app a single star on play store and tagging this issue so that atleast they'll start looking into it. Louder the noise higher the chance of it being picked up...
      03-14-2021, 07:27 PM   #18
uadissa
Australia
Can confirm apps in motion works in ID7. Seems like this is now a legacy issue for poor ID6 owners. Also wireless android auto and CarPlay available. So you don't really need in car apps like Spotify .
      03-15-2021, 03:24 AM   #19
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
In iDrive 7 you can code the BMW Drive Recorder, news and weather apps to work up to 63 kmph by default Australian spec BMW's will only work if the car is in park with the handbrake engaged
      03-19-2021, 10:09 PM   #20
uadissa
Australia
I was driving a loan car fro the dealer- 2021 G01 30i. Apps were working in motion . Unlikely dealer had the car coded
      03-21-2021, 03:23 AM   #21
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
Which ones worked whilst it was moving?
I have a G05 X5 and the BMW News Drive Recorder & Weather App would not work while the vehicle was moving without me coding them.
Apps in CarPlay & Android Auto however will without coding
      03-21-2021, 04:44 AM   #22
uadissa
Australia
Checked weather, news and bmw connected.
f30post
