EBox/ECU Fan Replacement
07-12-2017, 03:34 PM | #1 |
233
Rep 564
Can anyone link me to a good DIY? Can't really find one in my searches. Getting far too many random results when I search ecu or ebox fan replacement.
I did find some info stating to go from the glove box under the fuse panel using extensions and a torx bit to get the two screws off of the fan but other than this I really have no clue what else is required for the E90. I found this for a 7 series but I'm pretty certain it's not right: Disconnect battery Remove passenger side microfilter (assuming USA / left-hand drive) Remove microfilter clip above passenger side of e-box cover (1 screw) Remove e-box (electronics box) cover Unclip e-box fan connector (2-pin plug along interior edge of e-box closest to front of car) Remove IVM module Remove DME module Remove Valvetronic control module Remove any other modules remaining in the e-box because maybe your car is cooler than mine and you have more modules Remove plastic module cage (one screw at front-passenger, one screw at rear-driver) Remove e-box fan clamp (2 screws) Pull out e-box fan and its ductwork (it all just pulls apart) Clean out e-box and vent hole in base of e-box (rear-driver) -- Any help would be appreciated, thanks! |
07-15-2017, 10:31 PM | #2 | |
233
Rep 564
From here I couldn't figure out what to do, seems like I gotta come at it from inside the car but couldn't find anything that looked like the fan when looking through the glove box and behind the kick panel. |
07-15-2017, 11:08 PM | #4 |
233
Rep 564
07-15-2017, 11:12 PM | #5 |
310
Rep 1,016
07-15-2017, 11:23 PM | #6 | ||
233
Rep 564
Found some additional information if you're curious: Quote:
07-15-2017, 11:28 PM | #7 |
310
Rep 1,016
Anyway to find out if its working vs completely busted? Its good it can stand the heat without it but.. if the ECU goes isn't that like 1000 dollar fix?
07-15-2017, 11:53 PM | #8 | |
233
Rep 564
Not sure how much it costs, fan was $170 shipped though which is bs |
07-16-2017, 12:36 AM | #9 | |
310
Rep 1,016
07-17-2017, 09:07 PM | #10 |
233
Rep 564
Not that I could find. On another model (I think 7 series) there was a post regarding a replacement motor for the fan that cost ~$15 from RadioShack or something. But there wasn't much info for the E9x platform.
I could be wrong but if that BMW tech guy said it's for hot ass climates like Arizona then we should be okay. I also figure another possible reason for the fan is climates like in the middle East. Gets hot as fuck out there too. We don't see that sorta weather in Philly, but I still wanna get it replaced if I can. I'll post a DIY if anyone can point me in the right direction for pulling the old one out |
07-17-2017, 09:55 PM | #11 | |
233
Rep 564
Here's the DIY for the fan, looks like I gotta remove the fuse panel...damnit lol I spent like an hour trying to go through the dme box https://www.newtis.info/tisv2/a/en/e90-335i-lim/repair-manuals/12-engine-electrical-system/12-90-control-unit-box/Oantz3T Thank you! |
03-15-2018, 03:41 AM | #12 | |
Rep 35
I removed glovebox couldnt find the ebox fan like what you've shown in the above pic. |
