2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions How to remove lower trunk trim to install dynamat
      07-10-2017, 08:22 PM   #1
SliChillax
SliChillax's Avatar
Albania
486
Drives: Ex BMW owner, will return soon
As title states, I ordered dynamat to fill the trunk with it. I would like to know where can I find a step by step guide on how to safely remove everything to get to the bare metal of the car. Considering the battery is in the back, I'm assuming it's a bit more complicated than other cars.
      07-10-2017, 08:59 PM   #2
zipphreak
No_Country
454
Drives: m235xi
It's a lot of plastic pop rivets.. Get some plastic automotive trim tools, and a set of torx bits (their are two on top of the trunk mat if i remember correctly).
That should get you 90% of the way there, and just start pulling. I did some 80mil mat in my trunk, but i did not rip out the battery and such. I put it on any accessible open metal surfaces, and i took out both of the side trunk liners to get some more metal there.
      01-13-2018, 08:47 PM   #3
Mama Pills
Drives: 230i MSport
Did it help?
Did installing the dynamat reduce road noise much?
      01-15-2018, 02:25 AM   #4
SliChillax
SliChillax's Avatar
Albania
486
Just a little, not worth the time and money in my opinion.
      01-28-2018, 11:07 AM   #5
Mama Pills
Drives: 230i MSport
thanks
Thanks for the reply. I have some Dynamat left over from a MINI project (BIG benefit there) and was wondering if it was worth the effort. Thanks again.
      01-29-2018, 04:46 PM   #6
//M235ixD
//M235ixD's Avatar
88
Drives: 2015 //M235i xDrive
i now this is the the end to end guide but will get you started with removing the stuff in the trunk..
http://www.2addicts.com/forums/showt...ck+amp+install
2addicts
