07-03-2017, 08:48 AM | #1 |
19
Rep 49
I thought there was a temperature reading on the oil level??
I though I read before that there wasn?t an oil temperature reading on our cars. Well yesterday I noticed that upon firing up the car it displayed cold underneath the oil symbol with a temp gauge showing it warm up. I most be dumb as I have not seen this before. Here is the photo:
Please comment on whether this was already on the car. |
07-03-2017, 09:10 AM | #2 |
699
Rep 1,514
It's always been there, it's a combination of oil and water temperature though.
M3 Adjuster7909.00 M2Nebula547.50 |
07-03-2017, 11:35 AM | #4 |
4197
Rep 3,091
Drives: 991.2 Porsche GT3, BMW E46 M3
Garage List 1987 BMW 325is [10.00]
2004 BMW X3 [8.25] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
I always understood the car has no OIL temperature display in stock form.
Top temperature reading is outside temperature not related to Water/Oil. Second I believed to be also water temperature related and would go from "COLD" to "OK" after the car comes into operation temperature. Cross fingers it never sees "HOT". And bottom is just a graphical way of showing once more the water temperature in a bar form. Can someone please clarify? EDIT: Removed the image to avoid confusing other members.
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii Last edited by BAN_M2C; 07-03-2017 at 02:36 PM.. |
07-03-2017, 12:48 PM | #5 |
690
Rep 287
That image above is incorrect (bar) if the manual is to be believed.
The value for OK is a computed result of oil AND water temperature. You can find this on page 89 of the user manual AND in the M2 Technical training manual on page 67. So when critics cry "there's no oil temp gauge, wahh wahh", there technically is, and like others this is the page I keep on my instrument cluster by default. Sure, I'd rather see temp digits for oil, in that case the options are a P3 Gauge, Awron Display, or use the Torque app. It would be interesting if those with the above could do some testing to evaluate what the 'actual' readings are of the oil/water temp once the slider reaches OK.
F87 ///M2 - Journal
E46 ///M3 - Journal M2 Topics: Sport Mode Default | Comfort vs Sport on MPG | M2 Alcantara Dash Install | Air Filter DIY |
BAN_M2C4197.00 |
07-03-2017, 01:49 PM | #6 |
2545
Rep 3,968
For a M car, I would expect this to be a full-time "gauge" and not a selection within several other "info" options.
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual 2023 X3 M40i - loaded sans Park Assist Last edited by doug_999; 07-03-2017 at 02:04 PM.. |
nachob2317.00 |
07-03-2017, 02:31 PM | #7 | |
4197
Rep 3,091
I do run Torque Pro App and can do a check on the operating temps. I have yet to do an Autocross using this setup but will definitely use it and do some data logs thru the Torque Pro App. These temperatures were after a 30 min drive to work on a 90 degree Florida weather day.
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii Last edited by BAN_M2C; 07-03-2017 at 02:37 PM.. |
MerlinPurple690.00 |
07-03-2017, 04:21 PM | #9 | |
Moderator
30017
Rep 13,167
///M is art ↔ Artemis
07-03-2017, 07:34 PM | #10 | |
2281
Rep 3,305
Mike
2018 M5 and 2019 Porsche Boxster GTS Prior. '94 325is, '97 M3 Lux, '16 M2 |
07-03-2017, 07:41 PM | #12 | |
4197
Rep 3,091
Monitoring Engine Vitals on iDrive Display
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii |
07-03-2017, 09:28 PM | #13 | ||
Meh
929
Rep 781
Drives: M3CS & Cayman S
07-04-2017, 11:11 AM | #15 | ||
481
Rep 684
2004 E46 ///M3 SMG Convertible Carbon Blk\Imola
2017 LBB ///M2 DCT 2013 Porsche Boxster S |
BAN_M2C4197.00 |
07-05-2017, 01:45 PM | #18 |
this is the way
18461
Rep 8,589
