F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > What is the point of running radiator fan after shutting off engine?
Extreme Powerhouse
      07-01-2017, 06:23 PM   #1
bimmer456
2966
Drives: 340i
So I notice after some spirited driving on a hot day the car will run the radiator fan for about 5 minutes after turning off the engine. Since BMW switched back to a mechanical water pump after the reliability problems of the electric water pump failures with the e90, it would seem not to serve a purpose since the water pump doesn't operate with the engine not running. What do you think?
      07-01-2017, 07:02 PM   #2
anotheran
Sedan Driver
389
Drives: A nice car
it's to cool the turbo. Similar to this thread: http://f80.bimmerpost.com/forums/sho....php?t=1089216
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK
BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug
      07-01-2017, 07:19 PM   #3
bimmer456
2966
Drives: 340i
makes sense. I assume the turbo cooling pump also works prior to starting, that's the secondary motor sound coming from under the hood after the water pipe wooshing sound coming from the rear of the car when you unlock the door, being the low pressure pump priming the fuel system so as to put less strain on the high pressure fuel pump that is prone to failure in the E90. Now ironically the low pressure fuel pump is being recalled on some earlier F30's.
      07-02-2017, 05:01 AM   #4
skw
202
Drives: M340i
I had the lpfp go on my '14 F30.
Boston CCA 383036
'20 M340i
'18 MB GLS550
'07 4Runner V8 Limited 4WD
f30post
