06-30-2017, 11:13 AM | #1 |
20
Rep 51
91 vs 100 octane for performance?
Are there any noticeable HP gains switching from 91 to 100 octane? Found two gas stations that offer 100 at the pump sorta near me, wondering if it'll make a noticeable difference in engine performance on my '15 435i MPPK. Anybody have experience/knowledge on this?
06-30-2017, 11:38 AM | #2 |
981
Rep 1,560
I don't think you would see any difference unless you had mods on your car which could take advantage of the additional octane. Your car, from BMW, is setup to run best with the recommended octane.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
fourdirtyfive20.00 |
06-30-2017, 12:13 PM | #3 |
1039
Rep 1,509
If you don't hear knocking under acceleration, you don't need a higher octane rating. It isn't going to make your car faster or better performing.
06-30-2017, 12:16 PM | #4 |
20
Rep 51
Thanks for the response. If I were to install a Jb4 and set it to Map 5 (automatically determines boost based off fuel, temp, etc.), I would see a noticeable gain then?
06-30-2017, 12:17 PM | #5 |
772
Rep 1,502
Sounds like a huge waste of money. If you're an experienced track driver then maybe you'd notice and appreciate the difference on a track day. But for daily driving when you're not at max acceleration I can't see how it would make a difference.
06-30-2017, 12:20 PM | #6 |
20
Rep 51
that was my thought, thanks for clarifying.
06-30-2017, 12:23 PM | #7 |
1061
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
I've been tempted to throw in a tank of 100 as well just to see if it feels different. I know at the track when I've run 100 in my other car (not stock), it helped bring the ET down and MPH up. I'm curious to see if the higher octane helps my GC, given that it's flash tuned, in terms of seat of the pants etc. Guessing it'll run a LITTLE better but worthy of the $ difference, probably not lol.
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
06-30-2017, 12:57 PM | #8 |
8245
Rep 16,085
Higher octane is less volatile than lower octane, so it doesn't give more HP. What gives higher HP is higher compression and boost, which may require higher octane to prevent knocking. It would take a full blown race engine to need 100 octane.
06-30-2017, 03:02 PM | #9 |
1061
Rep 3,258
Is this why your 'friend' runs 89 octane? Higher HP?
25% 3M Tint| |
06-30-2017, 08:54 PM | #12 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Some dyno tests I did a while back on a stock 335is maxed out around 94.5 octane. With JB4/COBB stacked tunes & a few other things it ran better on pure 100.
Point is the engine can't use any higher octane than it can use. Going high in the engine can't use it just wastes money. You might do better with 93 the premium in NC & most east coast states but I really doubt much more will do anything.. If you are in a 91 state & want to play mix 91 & 100 to get different blends of octane. I had a fast street tune that used 50/50 mix of 93/100 for about 96 octane.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
06-30-2017, 09:03 PM | #13 | |
2070
Rep 2,639
But if you go FBO or add a tune like JB4 or BM3, then 100 octane would absolutely help. Better octane=less knock and better timing control. You can up the boost safely depending on your map or OTS map.
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
FSociety3812.50 |
06-30-2017, 10:40 PM | #14 | |
793
Rep 1,627
M4 in MG | 6 MT
06-30-2017, 10:50 PM | #15 |
3788
Rep 5,776
Here's my opinion: I have JB4 and DP. I regularly use e85 and have tried a full tank of 102 as well as a mix of 102, E85 and 91. I felt like everything was the same and therefore it is more economical to just use e85. When I did the whole tank of racing I ran map 7 and it was fast but I can't say it was more intense than 4.5 gallons of e85, the rest 91 on map 5.
Of course I am just talking butt feel and conditions can be different from day to day. And since the question is regarding the Mppk it might be irrelevant, but that is my experience on the octane effect on power. I also did this with my e90 and had the same perceived results.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
07-01-2017, 06:11 AM | #16 |
Human
932
Rep 1,200
IIRC the knock sensors in our cars should detect and correct anything way before the driver realizes there's an issue.
2023 BMW M4 CP xDr | 510HP / 650Nm | Isle of Man Green | Photo album
Sold 2018 BMW M4 DCT / ZCP| 450HP / 550Nm | Sakhir Orange | Photo album | Tribute Sold 2014 BMW 435xd | 360HP / 710Nm | Estoril Blue | Photo album 2010 BMW Z4 sDrive35i DKG | 306 HP / 400Nm | Space Gray | Photo album |
