F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > AUSTRALIA > Speed Limit Info Emulator
Extreme Powerhouse
      06-30-2017, 06:49 AM   #1
silencer2008
Australia
37
Drives: 2014 328i MSport
Have just bit the bullet and purchased a Speed Limit Info emulator from Ebay.
Doesn't require the KAFAS camera, and works by using the stored speed limit info from the NAV database and sends that to the KOMBI and HUD.
Only requires VO coding, and it's plug and play (depending which version you get).
Will keep everyone posted.
Link for item:
http://www.ebay.com/itm/Speed-Limit-...-/232019856877
Link for thread:
http://f30.bimmerpost.com/forums/sho....php?t=1203393
Fingers crossed everything works...
2014 328i MG , BM3 Stage 2, Injen Intake, M Performance Brakes+ Exhaust, CP + BP, FMIC, High Flow DP, NBT ID6
      06-30-2017, 06:39 PM   #2
gkgkgk
Australia
Drives: X7, 330i
I was let to believe, by the dealer, that the AU NAV database does not store speed limit info due to AU law & regulations.
Interested in knowing how this upload the speed limit info into the database.
Does it allow you to update the speed limit info in a regular basis (e.g. annually?)
Good luck OP, let us know if works as I want to get it too :P
      07-01-2017, 02:15 AM   #3
silencer2008
Australia
37
Yeah, BMW AG does not licence SLI data, but not sure if this data is present and blocked or not present at all. If it is present and blocked, the emulator should intercept signal and send it to kombi/hud accordingly.
have seen a few people who got it working with Australia next 2015 maps.
I've also just purchased the 2017 maps, and will try it out once the emulator arrives.
      07-01-2017, 02:59 AM   #4
ontheway
15
Drives: F31 MSport 328i
Very interested. I think SLI is available on other Aus BMW - I was looking at some recent brochures but may have missed that fine print. Do you know if it also supports KAFAS2?
      07-01-2017, 03:07 AM   #5
silencer2008
Australia
37
I've got kafas2 as well on my car. Will test it out and post and update.
      07-01-2017, 08:37 AM   #6
DOCTOR.Y
Eric_Y
Australia
103
Drives: 2016 340i, 2010 E92 M3
2016 bmw m3 f80  [0.00]
2010 M3 E92  [0.00]
Is the reading accurate? Would that read school zone or Sth?
      07-02-2017, 12:41 AM   #7
DOCTOR.Y
Eric_Y
Australia
103
2010 M3 E92  [0.00]
I drove a 440i today. This car has speed limit info, from front camera.
      07-06-2017, 01:29 PM   #8
silencer2008
Australia
37
Can confirm this works, tried it today and the speed limit info works great, changes to the limit on the road.
I guess NBT does store info of speed limits and the emulator intercepts that to be displayed.
Will post pics soon.
Appreciate 2
DOCTOR.Y102.50
AllaVodka634.00
      07-08-2017, 12:14 PM   #9
silencer2008
Australia
37
Tested the SLI emulator for a few days. Works as expected. Speed info changes almost immediately in a new zone without delay.
Some instances where the 3 dashes blink for a few seconds, which probably is more due to no speed info stored on the NBT database.
Install was simple, no splicing of wires, and coding was straight forward. Adding option code 8TH and VO coding NBT and Kombi.
woosh212.00
      07-10-2017, 08:19 AM   #10
gkgkgk
Australia
Drives: X7, 330i
Thanks for the update.
Does it react to school zone?
      07-10-2017, 08:28 AM   #11
silencer2008
Australia
37
It goes off the speed limits stored on the Nav database. School zones don't get shown on the emulator or any changes to speed limits while road works are going on.
It's more of a static system.
      02-02-2018, 05:11 AM   #12
Bambazonke
Bambazonke's Avatar
Australia
210
Drives: 2017 X5 & 2020 X5
  [0.00]
Also bit the bullet and have bought one for my F25 X3. Will give feedback once I receive it and install it.
Did you get any errors when VO coding the Kombi?
I have being playing around with the VO coding on my X5 and added 8TH as I thought it would work as I have all the hardware and thought it was only disabled in Australia for some technical reason in the X5. I have since found out you need a FSC code at some ridiculous cost for it to work.
I got faults with forward alert with braking function and person warning malfunctioning both when I added the code and later when I removed it. Not sure why.
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive
      02-20-2018, 04:54 AM   #13
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
My emulator has arrived unfortunately the cable supplied does not match my existing cable that plugs into my Kombi I have taken photos of my Kombi part number and the plug itself and have sent them to the seller and am now awaiting a reply
      02-20-2018, 05:14 PM   #14
x5mad
x5mad's Avatar
No_Country
352
Drives: iX 40
bmw  [0.00]
As most have seen the speed data is stored in the maps.
Initially the SLI was withdrawn from Australian market due to the camera/software being unable to read all of the different Australian signs reliably.
In the last year it is now available as all the kinks have been worked out.
If your car is recent but just before SLI was an option it may be possible to retrofit it from the dealer. It just needs the FSC from the dealer and them to install it. I've seen a few members do it already.
      02-20-2018, 08:25 PM   #15
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
My X5 assembled in August 2016 has the camera I will ask the dealer if they can add the 8TH option in the meantime I am still waiting for the eBay seller to resolve my issue with the emulator for the X3 that does not have the KAFAS2 camera.
      02-28-2018, 08:30 PM   #16
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
Problem solved
After watching the below video
I realised that I had to take the existing plug apart and fit the ebay supplied sli module cable male plug into the existing BMW supplied socket and then plug it into the instrument panel.
I then took the male plug from the wiring loom and clipped it into a supplied socket by the seller which then links into with the sli module.
VO coded the NBT2 and Kombi with 8TH and the speed limit came up with 50kmph before I even drove down the street! I have yet to test it out on the main roads but so far I am well satisfied with my purchase.
Anyone thinking of doing this that has an X3 or X5 would be advised to watch the above utube video as I had no idea at first how to remove the instrument panel as there are no torx screws holding it in like in the F30. I used two Allen keys to pull the spring clips down and release the panel
      03-02-2018, 04:29 AM   #17
kash_0
Australia
Drives: F30 340i MSport
Any suggestions to dealers in Syd that would be willing to help?
Trivett have no interest when I asked a little while ago
Believe my car has all the necessary hardware to have this retrofitted.
      03-02-2018, 05:38 PM   #18
x5mad
x5mad's Avatar
No_Country
352
Drives: iX 40
bmw  [0.00]
I can't remember which dealer it was that did the retrofit.
This is the BMW part number for the FSC 8TH
66 50 2 444 948 Speed Limit Info
But FSC isnt the only part that is required. Also 65 50 2 184 753 is required.
      03-03-2018, 12:11 AM   #19
kabongSteve
21
Drives: G20 340i xDrive
I had the dealer in Canberra upgrade my 330i to include speed limit info.
Cost around $1000, TYPICAL BMW costs. But works great.
Did the TPMS myself, for around $350, instead of 1500 from bmw
      03-04-2018, 04:50 AM   #20
silencer2008
Australia
37
Quick update guys:
The car was updated at the dealer to latest istep, wiped out the coding done previously. Recoded the car for speed limit info and the instances where the 3 blinks happen for the speed has not returned anymore.
If you do see the 3 blinks randomly appearing, would suggest getting the car updated through dealer to latest istep level. Just beware that this would wipe out all the stored codings.
      03-16-2018, 08:29 PM   #21
Bambazonke
Bambazonke's Avatar
Australia
210
  [0.00]
SLI emulator feedback
Been using the X3 out of town recently and have observed when I go off the main road onto a secondary bitumen road the speed limit indicator drops from 100 kph to a default 50 kph Not sure if this is because the data base for Central Qld is a bit sketchy or is it Australia wide?
Around town it is pretty good except around school zones and road works which is to be expected. Overall $140 well spent
      03-01-2019, 03:03 PM   #22
msk340i
1320
Drives: 340i M sport
Can it the coding be done with Bimmercode?
f30post
