06-29-2017, 02:04 PM | #1 |
10
Rep 28
Coding: Keep last driving mode
Always reverts back to Comfort like we all know, but is it possible to make it retain the last setting? (For example, I have to set it to Adaptive everytime).
Alternatively, is setting a different default (like Adaptive) also possible? Thanks |
06-30-2017, 05:08 PM | #4 |
2374
Rep 8,364
07-24-2017, 07:08 PM | #5 |
Rep 4
I´m a relatively new coder and have just managed to code MSA Memory on my G30. Can you share your insight as to where exactly i can code to always default to sport mode in my BDC_Body?
07-24-2017, 07:43 PM | #6 |
2374
Rep 8,364
07-28-2017, 04:36 PM | #7 |
Rep 4
07-28-2017, 04:37 PM | #8 |
2374
Rep 8,364
02-15-2018, 06:03 PM | #9 |
Bimmerfest coding member since 2012
Rep 16
G30 m550
I cannot find the right parameter in the 4 CAFD files for BCD_BODY2, can yhou help. I would like to have adaptive as default Thanks
BMW G30 m550i xDrive 2018
Born: 2017-09-11 Carbon Black, Black Nappa with Grey Poplar. Pkgs: Premium, Adv Driver Assist, Remote Parking, 668M 20 In, Adaptive suspension & Smartphone Z1Q, ZC5, ZK9, ZTV, 29X, 2VW, 4LQ, 4161, LZFK |
02-15-2018, 06:05 PM | #10 |
Rep 16
Is this the one and which value should be set?
02-15-2018, 09:20 PM | #11 |
2374
Rep 8,364
02-16-2018, 07:29 PM | #13 |
2374
Rep 8,364
07-22-2018, 03:39 PM | #14 |
2462
Rep 3,803
12-06-2018, 02:36 AM | #18 |
46
Rep 159
I'm trying to code this on M550i but I cannot find the right CAFD to do it. I'm using Esys 3.27.1 with Launcher Pro 3.2.1. Launcher doesn't seem to know about CAFDs as there is a lot of unknown parameters there.
There are 4 CAFDs under BDC_BODY2 but all of them gives me nothing when I'm searching FES. Is it so that M550i has something different than other cars or what is the problem? I cannot make any coding for BDC_BODY because of this. |
12-06-2018, 09:57 PM | #19 | |
2374
Rep 8,364
Make sure to 1. install 64-bit java in E-sys directory 2. Increase memory in Launcher Settings to 4-8 GB 3. remove unneeded kiswb in Launcher settings. |
12-11-2018, 01:25 PM | #20 |
46
Rep 159
Thanks, that did it I also managed to code off automatic headlights when light switch is in 0 position. Now it stays in DRL even if there is dark outside. The A mode puts headlights on depending of ambience lighting.
08-22-2020, 11:28 AM | #21 |
4411
Rep 7,449
On my f15 X5...it was doable using the Bimmercode app using coding selections found in the BDC & ICM modules. It did NOT require going to the EXPERT side. It was simple selections found in the aforementioned modules (BDC & ICM) under “DRIVING MODES”:
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
08-22-2020, 03:58 PM | #22 |
Rep 10
Connected Drive Services Help
Hi...I am new to these forums and looking for help on the activation of connected drive services. Any help would be really appreciated. Thanks
