06-25-2017, 09:14 PM | #1 |
119
Rep 152
Drives: F30 335i M-Sport
Questions about radar detectors
Just curious about people's opinions regarding radar detectors. Any recommendations? I've been thinking about the escort/passport 9500ix. Also does anyone know what blend mount I need for a F30 ? Also a DYI for the wire tap to the mirror ?
Instagram: BoostedF30
2013 F30 335i M-Sport 2002 E39 530i |
06-25-2017, 11:00 PM | #2 |
47
Rep 103
Not sure about the mounts and wiring, but I had a Valentine 1 that I was very happy with for a number of years. Gave it to my younger brother after my commute changed and I stopped needing it. Would definitely recommend looking into them.
2022 Porsche Taycan
2022 Porsche Cayenne GTS Coupe |
06-26-2017, 12:17 AM | #3 |
243
Rep 445
I know nothing about the latest tech; had one years ago that was useless. The wires in the cabin were a pain. Get a concealed install whatever you do.
06-26-2017, 01:10 AM | #4 |
139
Rep 467
Coming from the Escort 9500ix. Traded up to the 360 when I purchased the 440. Anyways, all are good - none are infallible, and you are not invincible to staters or police. The blendmount depends on which mirror you have. They're specialty mirrors. If you go onto Blendmount's site, it'll narrow down the mirrors to 2 types. Check your car and order accordingly. As for the mirrortap, you plug into the molex connector - all you need to know is which is the ground, and which is the positive 12v, red connector. There are a few threads around that tell you which is which, but you can also use a voltmeter.
06-26-2017, 01:48 AM | #5 |
42
Rep 503
I always had good luck with the 9500, but that was over 6 years ago that I last used it (cops in Hawaii only used laser). I just looked at the Radar Detector Forums a couple weeks ago (because cops here JUST started using Radar) and it looks like there are several new systems out there. The Escort still looks like a good option, but you might want to head over there to see the options.
06-26-2017, 07:11 AM | #6 |
4516
Rep 8,942
Max 360 just upgraded from Redline saved my butt this weekend. Roy had an article on the drive that's worth checking out, short of spending stupid money that's his recommendation.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
06-26-2017, 07:17 AM | #7 |
77
Rep 345
I have a Valentine 1. It used to be good but now every Audi, Volvo, and Mazda sets it off. The blind spot detection and active radar drives it nuts to the point it's totally useless.
06-26-2017, 07:36 AM | #8 |
343
Rep 2,118
It can be upgraded to new software that can detect the false signals from the active radars.
06-26-2017, 07:41 AM | #9 | |
4516
Rep 8,942
To be honest though the only reason I'd choose a V1 over the Max 360 is if I were planning to do a stealth install with that housing for the rear parcel shelf. The addition of escort live to the 360 with full integration with a smart phone is a real game changer. I wouldn't throw away a perfectly good V1 to get the escort, but if you're starting from scratch I'd choose the 360.
2022 Macan S
06-26-2017, 08:25 AM | #10 | |
981
Rep 1,560
OP, as you can see, there are many detectors out there which many people like, you should read up on them and see which ones have the features you would like.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
06-26-2017, 08:36 AM | #11 | |
4516
Rep 8,942
OP what you REALLY need to do is figure out how much information you can/desire to process while driving. For most folks out there something like a Redline would be totally fine, if you get an alert you slow down. V1 would be next step up with directional arrows, then you can go all the way with 360, Escort Live, Waze as a secondary data source while running police scanner app in the background. That said it's next to impossible to monitor all of that shit while driving solo so you're perhaps better off adopting a less is more approach or having a copilot.
2022 Macan S
06-26-2017, 08:37 AM | #12 |
4516
Rep 8,942
FYI this is a screen shot from Escort Live
2022 Macan S
06-26-2017, 10:02 AM | #13 |
364
Rep 775
Valentine 1 with mirror tap. Also use Waze to know what else might be happening.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
06-26-2017, 10:55 AM | #14 |
2413
Rep 4,451
Drives: '23 X1 28i xDrive
Waze?
06-26-2017, 11:36 AM | #15 |
364
Rep 775
Yes the V1 unit, in combo with Waze, lets me know know what's going on. Situation awareness, number and location (V1) plus crowd-sourced data (Waze) works
Enjoy the Drive,
06-26-2017, 11:50 AM | #16 |
4516
Rep 8,942
Escort Live is basically like Waze taken to the next level. If you run both you are really covered. The nice thing about EL is that when a threat is coming up ahead of you even if you don't look at map the detector beeps and tells you 4000 meters or whatever ahead KA threat, for example.
2022 Macan S
06-26-2017, 12:18 PM | #17 |
2564
Rep 1,710
Also depends where you live. In my area cops almost exclusively use laser so lots of guys get laser jammers.
enjoythemusic364.00 |
06-26-2017, 02:15 PM | #18 | |
981
Rep 1,560
It is beginning to look like there are a few people out there who are in serious conflict with their local traffic laws. Either that or they are getting ready for the next Gum Ball Rally.
06-26-2017, 02:43 PM | #19 | |
4516
Rep 8,942
Waaaay too much to monitor if you're the only one in the car. With a copilot though it was awesome. We definitely avoided one ticket. At first she thought I was an idiot but got kind of into it towards the end. For the avoided ticket she actually said "LEO ahead on Waze... hold steady... Escort Live confirmed KA in 3500 yards check speed to 80 mph."
2022 Macan S
06-26-2017, 02:50 PM | #20 |
3493
Rep 3,213
I've been an Escort Radar guy since the 80s and the 360 with its directional arrows really takes the last chink out of Valentine's armor. fwiw, I run Escort Live and Waze. EL is nice in that it's so integrated (and you can mute the detector just by tapping your phone's screen), but frankly Waze has a much bigger network of users and therefore has many more and more timely alerts. I highly recommend hard-wiring the 360, hide all the cables, and you don't have anything to think about.*
And yes, COKen, I have had an intimate relationship with LEOs for many, many years. * Unless you're also looking for laser protection, in which case ALP is the way to go.
CURRENT: '24 M4C Conv
RETIRED : '23 M8C Conv | '20 X4 M40i | '18 M4 6MT | '13 M5 6MT | '08 550i 6MT | '04 545i 6MT | '98 540i 6MT | '94 530i 5MT | '84 528e 5MT Other retirees from Chevrolet, Buick, Subaru, Honda, Acura, Merkur(!), Volvo, Saab, Audi and Porsche |
06-26-2017, 02:53 PM | #21 |
4516
Rep 8,942
Escort with mirror tap and either blend mount or the $10 permanent one from eBay (which I run) is without a doubt the way to go. Clean install, inexpensive, and under 15 minutes.
2022 Macan S
06-26-2017, 02:58 PM | #22 |
3493
Rep 3,213
Sold!!
