06-25-2017, 11:46 AM | #1 |
4185
Rep 3,077
Drives: 991.2 Porsche GT3, BMW E46 M3
Garage List 1987 BMW 325is [10.00]
2004 BMW X3 [6.50] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
FS Sport Cat + Dinan Resonator Delete + Dinan Free Flow Exhaust
Have read about many combinations around posted but not sure if this combo has been shared.
I had full FS Downpipe + Bypass but due to fitment issues decided to remove the Bypass and replace with the Dinan Resonator Delete and Dinan Free Flow muffler. Power delivery feels much more linear, turbo can be heard much more clearly now. Will dyno to see if the numbers changed from the previous setup.
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii |
06-25-2017, 11:56 AM | #3 |
4185
Rep 3,077
None, I did code out ASD which might help also.. with the Bypass you would lose the OEM flap and there was some drone around 2800-3000 RPM. Having a conversation in the car at 80mph in 6th gear was a bit tough.
I am not 100% sure of this, maybe some others can chip in on how the stock flap works. Is the flap progressive in Sport and Sport+? Meaning it opens and closes as you get on the throttle more? Or is it just closed/open? Regardless, with the DINAN setup you retain the flap control and when I am in 6th gear on the highway doing 75-80 mph you can have a conversation in the car with no issues.
Follow me on IG
06-25-2017, 12:18 PM | #4 |
375
Rep 507
So you are saying with your prior setup there was drone but with the Dinan setup there is none?
Present: 21 M2C 6MT/Ford something
Past: M2 Mineral Grey 6MT Past: BMW e30 m52 turbo 628whp/558wtq |
06-25-2017, 12:22 PM | #5 | |
4185
Rep 3,077
I should do some vids from the interior under load and at cruising speeds.
Follow me on IG
