06-24-2017, 01:48 PM | #1 |
280
Rep 278
Has this happened to anyone? I did a search but not finding anything. Checked fuses and all seem ok. Car is a year old and has 10k miles. This is just annoying.
Just started it this morning after is sat in the garage all night and no air comes out at all. Let it sit and tried again, still nothing. Edit: I found this thread http://www.e90post.com/forums/showthread.php?t=1264502 Unplugged and plugged the power to the blower and nothing. Didn't see any moisture or signs of water or condensation. Lame.... |
06-24-2017, 05:22 PM | #4 |
280
Rep 278
Yup. That's what I'm looking to do on Monday. They need to do the recall on the long bolt replacement as well. It's just 97 degrees in Florida plus the heat index so the timing stinks.
Tumbleweeds78125.50 sl1350.00 |
06-25-2017, 04:38 PM | #7 |
2281
Rep 3,305
Sorry to hear that, please post solution to this issue.
Mike
2018 M5 and 2019 Porsche Boxster GTS Prior. '94 325is, '97 M3 Lux, '16 M2 |
06-25-2017, 06:27 PM | #9 |
2281
Rep 3,305
Sometimes electric motors have a dead spot on the coil.It has to just happen to stop just at the correct site for the circuit to be broken. Try using a vacuum cleaner reversed to blow air into a vent to turn the blower a bit. Then it may start back up!
Mike
Em-too279.50 |
06-25-2017, 06:43 PM | #10 |
280
Rep 278
Thanks. Was worth a try but no dice. I even have a Metro Vac-n-Blo so I know it was forceful enough to get it to spin.
06-26-2017, 02:55 PM | #11 |
2281
Rep 3,305
Worth a try. Hopefully it's an easy swap out repair.
Mike
06-26-2017, 07:42 PM | #12 |
280
Rep 278
Tumbleweeds78125.50 |
06-26-2017, 07:55 PM | #13 |
126
Rep 133
06-26-2017, 08:05 PM | #14 |
2281
Rep 3,305
What does Blower motor resistor refer to? Is it just that, a resistor on the motor that can be replaced without buying an entire new blower? I had to replace one in my RS. It was $400 or so and was easy enough to get at. But a resistor would be a buck!
Mike
06-26-2017, 08:39 PM | #15 | |
280
Rep 278
I think it might have been going for awhile as I recall the pulsating vibration but I didn't know what it was. |
06-27-2017, 05:24 PM | #16 | |
2281
Rep 3,305
Mike
Luyi_pr9.50 |
06-27-2017, 05:51 PM | #17 |
280
Rep 278
Yup! I can tell also by fact that 1) my passenger seat was all that way back and 2) there was a nice stain from a dirty hand on the carbon fibre trim above the glove compartment.
