06-23-2017, 08:41 PM | #1 |
BMW forever!
1389
Rep 2,418
Discovered new open area in rear seat
I just found an open area in the rear seat behind the driver. It looks like something is missing. Please see attached picture.
Does anyone have the same open space? Is this expected or did the dealer or BMW mess up something? If something is supposed to go in there, please let me know and if you have a picture to share, that will be great. Thanks!
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
06-25-2017, 10:28 AM | #2 |
826
Rep 1,342
Middle row seat belt.
tturedraider4974.50 |
06-25-2017, 03:00 PM | #3 |
114
Rep 243
Yeah, the receiving end of the belt is meant to fit down into the crack of the seat. Looks like it's just been pushed too far. The belt will be there, just all the way retracted or hooked into it's storage buckle on the rear parcel shelf.
06-26-2017, 01:52 AM | #4 |
42
Rep 503
Interesting. That looks like the LATCH system for a child's car seat, at least exactly what is in my car. But is that plastic cover above the seat belt the LATCH system? If so, when did BMW start putting LATCH in the open like that.
06-27-2017, 02:27 PM | #5 |
105
Rep 327
Mine is under the seat. I removed it to hard wire my radar detector (ran wire to trunk) and it's a PITA to get those through the holes on the seat. There's just not enough slack.
Mods: MHD Stage 2+ FlexFuel, xHP Stage 3, VRSF 5" HD Intercooler, VRSF Charge Pipe, CircuitWerks Catless DP, AFE Pro Dry S Intake filter, Eldor coils, NGK 97506 @ .026, Bilstein B14 coils.
07-16-2017, 02:35 PM | #6 |
Rep 5
2015 320i Rear seat removal
The bench seat pops up easy, I have removed the 2 T45 bolts between the buckles. I have a fixed non lowered seat back. Looked in trunk and no screw driver entry to turn to pop the seat. I have lifted up to try to release but will not budge.....where is the other release I am missing? Thanks
07-17-2017, 07:05 AM | #7 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
Just asking...why did you run a wire to the trunk instead of running the wire to the power receptacle underneath the right side of the dash closest to the center console? It's a standalone circuit and is easy to splice into.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
07-17-2017, 08:25 AM | #8 |
105
Rep 327
Because now the radar detector turns off with the ignition. Before it would stay on until it was manually turned off (with cigarette lighter cable).
07-17-2017, 08:36 AM | #9 |
260
Rep 955
07-17-2017, 08:46 AM | #10 |
105
Rep 327
I don't wanna wait that long for power to turn off on my radar detector. Now it turns off within 5 seconds.
07-18-2017, 07:04 AM | #11 | |
1837
Rep 6,990
So if I'm interpreting things correctly, you have a wire going directly to the positive battery terminal in the trunk and somehow turning off the ignition breaks that circuit? Not sure I follow how that works.
07-18-2017, 07:33 AM | #12 | |
105
Rep 327
