F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > What is the consensus on gaskets and water pump on F series?
Extreme Powerhouse
      06-22-2017, 12:18 PM   #1
WhiteBeard
151
Drives: slowly
Coming from e90 gaskets were a plague - it was not if, it was when they will fail and start leaking requiring to change them. Most PITA was oil pan gasket requiring to drop subframe only to get to oil pan. Not to mention AWD nightmare - front axle going through oil pan! and complicating process even further
Are gasket issues sorted out in F series? Is water pump sorted as well?
      06-22-2017, 12:43 PM   #2
enjoythemusic
enjoythemusic's Avatar
364
Drives: 2014 BMW 435i Dinan Stage 4
The F32 and the like with N55/8AT seem pretty solid. That's one of the reasons why i got a used one a few months back. JMHO.
Enjoy the Drive,
Steven
2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S.
      06-22-2017, 12:47 PM   #3
Dank28i
Drives: 2011 528i
the N55 is a very solid motor. but there is no way to tell when your pump and gaskets will start to go because every engine is different. alot of it depends on how the engine was treated when new.
on one end of the spectrum, you have failing gaskets at 70k miles. then there are others who have perfectly fine gaskets past this mileage. it is the same story with the pump.
f30post
