M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      06-21-2017, 03:51 PM   #1
KMORGSM5
KMORGSM5's Avatar
317
Drives: 14 CP M5
MOTUL Sport 5W40
Anyone here run this in their S63TU? This is a full ester based Synthetic and should well outperform that BMW uses from factory for our M Cars.
Just hit 44k and sent my oil out for Black Stone Oil Analysis.
Depending on what the report comes back with might use this at next oil change.
      06-24-2017, 08:43 AM   #2
123Britt
287
Drives: 15 M235i AT
How long do you keep your car?
In South Florida - I do think a 5W-40 is good choice. But I am also a believer in OCI at 5-6K miles. Motul is a great brand. If out of warranty I would choose Redline's thick 5W-30 or possibly the 5W-40 depending on your type of driving.
I have the N55 in my M235i and choose PP EURO 5W-40 and leaning toward RL 5W-30 post due to the all ester -- which as you know is superior in handling the heat.
If you plan on keeping the car less than 100k then simply follow BMW standard intervals with any LL-01 oil.
      06-26-2017, 09:40 AM   #3
KMORGSM5
KMORGSM5's Avatar
317
Drives: 14 CP M5
how many liters does the S63TU Take?
      06-26-2017, 05:25 PM   #4
123Britt
287
Drives: 15 M235i AT
Buy 9 QTS
8.5 liters or 9 qts with some debate - but I am sure you can put in 8.5 liters and check the level. Some just put in 9 liters and call it a day.
      06-26-2017, 06:01 PM   #5
ARC550
446
Drives: M3, X5, 720s, X5, 750xi
I use Motul 0w40 just put it in. 1k miles runs great
lanab39.00
      06-27-2017, 07:56 AM   #6
KMORGSM5
KMORGSM5's Avatar
317
Drives: 14 CP M5
Thanks guys, will use this at next oil change.
      07-18-2017, 09:32 PM   #7
BMWAUDIO
64
Drives: F90 M5 Frozen Gray , 997 C4S
Was your M6 consuming oil before ?
How is it with the Motul 0w40 ?
Thanks
      07-19-2017, 09:43 AM   #8
ARC550
446
Thanks
Thicker oil noticed less consumption. I can only assume with 10W60 the consumption will be non existent lol
      07-26-2017, 07:13 PM   #9
BMWAUDIO
64
Wont that cause the motor to be more slugish ?
      07-27-2017, 12:51 AM   #10
ARC550
446
That's what I hear.. at the same time these engines need thicker oil. 5w30 is simply crap
      08-13-2017, 05:15 PM   #11
finlandm5f10
24
Drives: BMW M5 F10&Audi RS6 C7 2016
S63TU engine oil capacity 9,5l
Etkabmw.com
      08-31-2017, 03:03 PM   #12
lanab
39
Drives: M5 F10 MY12
Motul 0W40 is the best for this engine, i changed from Mobil1.
      09-02-2017, 01:39 AM   #13
AWF10M5
222
Drives: f10 m5
How was Mobil 0w40 I am doing oil change with this tomorrow I'm at 48k just got car
Any reason for swirchchow was oil consumption with the mobil
      10-23-2017, 01:17 PM   #14
CSL335i
Hungary
207
Drives: M2 and...
Do you mean Motul 300V 5w40?
I have used it in my F10 M5 and i truly believe it is a very good oil.
Only limitation here, that this oil is not a long-life type oil and depend on usage on road, the maxmimum oil change intervall, which i suggest is 8.000 km. If tracked heavily, than might be maximum 2.000 - 3.000 km. Oil analyses can prove the longetivity of change intervall anyway.
Motul 300V 0w40 is also a very good oil, in my F13 M6 i am using BMW M Performance 0w40 il (aka SHell Pureplus) with 10.000 km change interval.
If you can effort the more frequent oil change intervall (5k - 8k than 10 or 12k), than Motul 300V is a fantastic oil to choose.
      12-12-2017, 04:11 AM   #15
alienstudio
alienstudio's Avatar
30
Drives: F10 M5 CP | G05 X5 40i
Just wondering if you ended up using the motul 5w-40. Im debating on using motul 0w-40 or 5w-40.
2014 F10 M5 CP | Black Sapphire Metallic | Sakhire Orange Interior | 343M Wheels | Afe CF Air Scoop | Charcoal Filter Delete | AutoTecknic CF Steering Wheel Trim
      12-12-2017, 05:28 PM   #16
BMWAUDIO
64
I went with Redline 0W30
      12-12-2017, 07:25 PM   #17
celicatoe46m3
47
Drives: E60 M5 & E46 M3
This is a perfect topic. I'm out of warranty too and I'm using:
Liqui Moly 2332 LEICHTLAUF High Tech 5 W - 40
There are some different versions of this, but I'm open to other options.
Search this Thread:
Advanced Search
m5post
