06-17-2017, 03:14 PM | #1 |
151
Rep 545
Does M Sport 335i has lower than stock suspension?
So highest sitting so to speak is AWD suspension. A bit lower sits RWD (stock). Am I correct assuming that M Sport suspension on a RWD 335 sits a bit lower than stock RWD?
How does adaptive suspension changes things if any? |
06-17-2017, 06:28 PM | #2 |
279
Rep 689
i think its 10mm difference
WhiteBeard151.00 |
06-17-2017, 06:50 PM | #3 |
Sedan Driver
389
Rep 1,018
Adaptive on a xDrive is same height as base suspension. Invest in some lower springs and shocks for the money you save from depreciation
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug Last edited by anotheran; 06-17-2017 at 08:51 PM.. |
WhiteBeard151.00 Dank28i5.50 |
06-17-2017, 10:24 PM | #4 |
Mr. Discombobulator
160
Rep 162
M Sport suspension (RWD) is 20mm lower than standard.
'14 MSport 335i | Melbourne Red | MPE | MPBBK | MPS | MPLSD | xHP Stage 3 | MHD Stage 2
06-17-2017, 10:58 PM | #5 |
4975
Rep 6,241
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
Only 10 lower.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
WhiteBeard151.00 metallicpea714.00 |
06-18-2017, 05:38 AM | #6 |
Sarcasm while you wait.
149
Rep 118
Drives: 2017 F33 B58 xDrive
WhiteBeard151.00 |
06-18-2017, 08:09 AM | #7 |
1268
Rep 2,957
Pretty sure it's 10mm. 20 is almost an entire inch
http://www.bimmerfile.com/2011/10/14...e-a-must-have/
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
06-18-2017, 11:33 AM | #8 | |
149
Rep 118
WhiteBeard151.00 |
06-18-2017, 12:44 PM | #9 |
GasCompressor
333
Rep 564
Standard suspension is considered to be on RWD versions of Base, Modern and Luxury Lines.
RWD Sport and RWD M-Sport models are -10MM lower than standard (these have the 704 sport suspension). The RWD versions of Sport and M-Sport are 20MM lower (about 3/4") than ALL xDrive models. ALL xDrive models are +10MM over standard and ALL contain same springs regardless of model (this includes Sport and M-Sport models). An xDrive must have DHP (Dynamic Handling Package) to adjust to a stiffer suspension, HOWEVER, this does not change the suspension height in either direction! Extra clearance is for winter conditions and for front wheel drive gear.
2022 Porsche 911 Cabriolet Agate Grey/Black PDK 2019 440i M-Sport Smoke Topaz Metallic/Opel (Sold) 2014 335i M-Sport Black/Beige MPPK/MPE (Totaled) 2013 328i Sport xDrive Imperial Blue/Grey (Sold) |
06-18-2017, 01:54 PM | #10 | |
714
Rep 1,329
WhiteBeard151.00 |
06-18-2017, 04:14 PM | #11 |
1268
Rep 2,957
I may have misread the question then. I was comparing RWD sport vs RWD non sport. You are correct the Xdrive could be 20mm higher than RWD sport.
WhiteBeard151.00 |
06-19-2017, 11:52 PM | #12 | |
2191
Rep 2,557
06-20-2017, 05:01 AM | #13 | |
714
Rep 1,329
The xdrive suspension sits higher than standard (non sport) rwd suspension.
2002 325i sport - sold 2009 135i M sport - sold
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT |
razzy53082.00 Lance_Goodthrust4.50 |
06-20-2017, 06:45 AM | #14 |
149
Rep 118
metallicpea714.00 razzy53082.00 |
06-20-2017, 07:01 AM | #15 |
714
Rep 1,329
No, you are correct about me being correct that he is incorrect.
06-20-2017, 08:12 AM | #16 |
151
Rep 545
So AWD sits 10mm higher than 704 RWD standard. Then M-Sport sits 10mm lower than 704 RWD standard. In other words there's a 20mm difference between AWD and RWD M-Sport suspension. I'm assuming besides ride height M-Sport has stiffer springs correct? Are shocks same or they have different stiffness too?
06-20-2017, 09:36 AM | #17 | |
714
Rep 1,329
Lets use a RWD model without sport options as a baseline. Xdrive - either with or without adaptive sits 10mm higher sport or M sport - either with or without adaptive sits 10mm lower I do not believe adaptive effects the ride height in either application, but not sure how the actual spring rates are effected - if at all. Adaptive changes the shocks/dampers so that they are adjustable via a valve to range from softer to firmer. System monitors all kinds of data to determine how soft the dampers should be and continuously adjusts them as you drive. Also comfort, sport & sport + has some effect on logic for adaptive dampers. So yes, 20mm between Xdrive and sport Yes stiffer springs, although exact specs are hard to pinpoint and yes, historically, shocks/dampers are different too and are matched with each of the 5 different suspension set-ups. FWIW, I researched this a bit and test drove and selected the non adaptive sport suspension - 704 and am very happy with it. I think it matched with the right tires is the typical BMW sport suspension, although other suspension set-up have merit for others.
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT Last edited by metallicpea; 06-20-2017 at 09:59 AM.. |
Calvin361061.50 |
06-20-2017, 11:01 AM | #18 | ||
2191
Rep 2,557
06-20-2017, 11:19 AM | #19 |
1268
Rep 2,957
I doubt it's 10mm higher but even BMWUSA.com lists the RWD at 56.3" height and 56.5" height for xdrive
06-20-2017, 11:33 AM | #20 |
2191
Rep 2,557
06-20-2017, 11:40 AM | #21 | |
714
Rep 1,329
To my eye the xdrive looks higher - next time I'm at the dealer I will measure for myself. I never considered the xdrive, so never looked super close at them - I spent my time comparing the various RWD versions as that is what I was buying.
06-21-2017, 10:56 AM | #22 |
128
Rep 262
So I swopped out my springs on my 2013 335i XDrive 6MT for a set of M Sport Springs from a 2013 335 M Sport RWD.....retained same shocks cos the XDrive fronts are different. Dropped the car 20MM all around. Reduced the roll almost completely and firmed up the suspension by a seat of the pants 10-15%.
WhiteBeard151.00 razzy53082.00 |
