06-17-2017, 08:57 AM | #1 |
64
Rep 127
Does 340i Have a Fuel Reserve?
Anotherwards, when the remaining mileage range reaches 0 will the car literally have no fuel left, or is there like a gallon or so of safety reserve that's not accounted for in the 'range to empty?
06-17-2017, 09:06 AM | #2 |
2966
Rep 6,003
It typically shows fuel reserve when there is just under a quarter left or 50 miles indicated. I usually fill up before then to avoid stressing the fuel pump. I've seen folks indicating about a gallon left at 0 miles so maybe 20 miles driving normally I'd guess. I wouldn't run it that low though.
insanecoder1412.00 |
06-17-2017, 10:12 AM | #4 |
Curmudgeon and Pedant
690
Rep 3,489
06-17-2017, 01:28 PM | #5 |
4975
Rep 6,241
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
06-17-2017, 04:31 PM | #7 |
279
Rep 689
since so many people said I'm wasting my time filling up (in a similar thread) lol when at half a tank i decided to start waiting till it goes down to zero sounds fun naaa it won't be harmful to my 64k BMW its fun and ill save time LOL
06-17-2017, 04:31 PM | #8 |
279
Rep 689
06-17-2017, 05:14 PM | #10 |
279
Rep 689
06-17-2017, 05:45 PM | #11 |
43
Rep 165
06-18-2017, 01:58 AM | #12 |
76
Rep 145
Drives: 2016 F30 340i
06-18-2017, 01:14 PM | #13 |
1039
Rep 1,509
The Porsche 356 and VWs of the same era had an actual mechanical fuel reserve. Most didn't have a fuel gauge... and the gauges weren't particularly reliable
There was an L-shaped lever on the firewall under the dash. It connected to a petcock (valve) that had three positions: on, off and reserve. In the on position, it connected to a pickup tube that extended a couple of inches up into the fuel tank. If the fuel level dropped below the pickup tube, the engine would start to starve out. The driver could reach for the petcock lever and turn it from the on (down) position to the reserve (90° right) position, opening the outlet in the bottom of the tank. There was about six litres of fuel between the pickup and the outlet, which gave about 40 miles of cruising range. Of course, those cars had carbs. You wouldn't want to starve out fuel injectors... and trying to reach under the dash while the car was moving was just a little unsafe. Lack of seat belts made it easier. I prefer the comfort and safety of a modern car, but there's something to be said about driving a car with an engine I could remove myself with nothing but a floor jack. |
06-18-2017, 01:49 PM | #14 |
Cheapskate
4450
Rep 4,993
i hate filling up my tank. i want the frequency to be as low as possible. one of the reasons i got a 4 series over a 2 series was the extra 2-gallons of fuel capacity in the tank. some of us just know that filling up when the tank is low isn't the end of the world.
that being said, if you read the thread, you'll see the OP is concerned about mixing e85. it's also helpful to know how much fuel you have if you're manually calculating mpg, running gas down to a half tank for a day at a drag strip, etc. |
06-18-2017, 01:51 PM | #15 |
714
Rep 1,329
Well, refilling at half a tank just causes you to stop at the gas station twice as often. I prefer as few pit stops as possible, wish the tank weren't quite so small.
I will say, the amount past 0 is smaller on my F30 than any car I have ever owned. It is less than half a gallon in my experience. |
06-18-2017, 04:10 PM | #17 | |
64
Rep 127
Thats the reserve set up I had on my old zx10r ages ago.
06-18-2017, 05:22 PM | #18 | |
1412
Rep 3,211
why mess around? just doesnt make any sense |
bimmer4562966.00 |
06-19-2017, 07:31 AM | #19 |
Driver
465
Rep 1,002
I used to run my e90 down to zero on fuel gauge regularly... ended up needing a new cat (luckily within warranty) which would have cost me getting on for a grand!!! While it wasn't definitely the cause, on googling the subject I found that running low regularly is a possible cause of cat damage!! So, I suggest not taking that risk!!
06-19-2017, 09:17 AM | #20 |
Cheapskate
4450
Rep 4,993
that doesn't make any sense. how could low fuel cause a cat to go bad
06-19-2017, 09:18 AM | #21 |
2966
Rep 6,003
06-19-2017, 09:20 AM | #22 | |
Cheapskate
4450
Rep 4,993
It really isn't that serious. your fuel pump basket makes sure the pump stays submerged in fuel even when you're low on fuel. If anything it's better the cycle the fuel through the system so you don't have old fuel sloshing around in the tank. that just make your fuel filter work harder. |
