06-10-2017, 11:26 AM | #1 |
21
Rep 87
Engine Cover Removal HELP!
Hey guys;
I feel stupid asking this, but how do you remove the plastic engine cover of the M235i? I just got a JB+ and wanted to install it. In order to get to the TMAP sensor I believe the engine cover has to be removed. I did a YT search on BMW engine cover removal and it showed the cover is screwed on. My engine cover has no screws. I tried to pull it off but it's on tight. Any help, illustrations, etc would be appreciated. |
06-10-2017, 12:03 PM | #3 |
4516
Rep 8,942
Start at the front. Do you happen to have speakers at home with removable grilles? If you do pop one off and look at it. There's a hole with a rubber ball that pressure fits in. The engine cover is the exact same thing just slightly beefier.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
06-10-2017, 04:06 PM | #5 |
10
Rep 67
Drivers side middle there is the throttle body just below is the sensor you want. I used a panel clip tool to release the clip from the front as the release tab is very small.
06-10-2017, 04:08 PM | #6 |
10
Rep 67
Instructions are located here http://www.burgertuning.com/f_series...all_tuner.html
06-10-2017, 04:58 PM | #9 |
21
Rep 87
The diagram on Burger instructions looks different than what I see in my engine bay. I will put the cover back on and see if I can see the sensor you're describing.
06-10-2017, 08:18 PM | #14 |
21
Rep 87
Thanks for confirming the sensor in my 2nd pic. I can't get the damn connector off, even with a small screw driver. I have a friend that's an Audi mechanic. Maybe he has a tool for this.
06-10-2017, 08:29 PM | #15 |
10
Rep 67
are you sliding the screw driver under the clip at the front of the connector (sensor side not the back where the wire come out)? A small flat head under the clip and the wiggle the connector out. Make sure to leave the screwdriver under the clip while removing it.
06-10-2017, 08:51 PM | #17 |
21
Rep 87
Thanks Redmoe I will try again tomorrow when there is daylight.
BTW I snapped the engine cover back on. Is it normal that the front right side has a little play in it if u lift it lightly with your fingers? I didn't test how it felt prior to removing it. I'm fairly certain all 4 pegs are back in place. |
06-13-2017, 09:08 AM | #19 | |
341
Rep 1,184
I always had a hard time getting the connection around the big rubber ring as well. |
06-19-2017, 08:58 PM | #20 |
21
Rep 87
Guys, I was finally able to get that damn connector off to install the JB+ installed today. Took it for a test drive and it does seem to give a nice little boost. I'm sure as the car adapts I will feel it even more. Nice relatively easy mod and now my M235i is faster than a stock M240i
06-19-2017, 11:05 PM | #22 |
21
Rep 87
Thanks Redmoe.
So just for clarity, JB+ Factory setting +3PSI product produces: wHP: +35 wTQ: +45 If you want to translate this to engine HP and TQ increases do you add 15%? SO a stock M235i: HP: 320 -----> 360 w JB+ TQ: 330 ----> 380 w JB+ Is this correct? |
