06-06-2017, 08:15 AM | #1 |
151
Rep 545
RWD vs AWD F30 335 for modding?
I narrowed down my choice to F30 335 with M-Performance package and 8-spd AT, but I'm on a fence with RWD vs AWD. I can drive both in winter - that's not a problem, but I have questions about modding potential or limitations of AWD? Anyone know if AWD in F30 has same issues like in E90? I'm talking about front axles going through oil pan and nightmare to change or work on it when/if needed and also in E90 AWD was more or less weakest point when modding the car (it usually went before transmission or other parts). I know F30 can't be modded as high as n54, but still if I'm looking at 500whp+ I need to know if AWD is the weakest link in F30 335
Thanks |
06-06-2017, 08:17 PM | #2 |
BimmerPost Supporting Vendor
24198
Rep 190,805
I would get RWD unless Xdrive is a must in your area during winter
06-06-2017, 08:30 PM | #3 |
54
Rep 297
If AWD isn't a requirement AND you plan on staying below like 500whp, go RWD. I live in New England and got xdrive. Now I'm wishing I got rwd almost. Or an m3. All of the good suspension parts are for rwd. And installing the dp and chargepipes etc are more difficult with xdrive. Not to mention added weight and ever so slight understeer.
06-06-2017, 08:37 PM | #4 |
4975
Rep 6,241
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
RWD
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
06-06-2017, 09:08 PM | #6 |
151
Rep 545
To put it simply I'm coming from a under-powered slow 2007 e90 328xi AT with n51 engine - it's basically 0-60 in 8 sec at best - yes, I'm right there with minivans and SUVs. I had almost 10 years of this and now want to change to something a lot more powerful. I was thinking about n54, but it looks like n55 is a better choice, more reliable. I really like F30 design, it has grown on me and I decided this time to go for 335 F30 and mod it to the max
06-06-2017, 09:13 PM | #7 |
GasCompressor
333
Rep 564
RWD M-Sport is 20 MM lower center of gravity and is 125 pounds lighter on the front end! This gives better balance and handling. The xDrive may have the initial off line acceleration (hence the slightly quicker 0-60 time) but you lose in every other area (heavier steering, more body roll, etc.). Get RWD!
2022 Porsche 911 Cabriolet Agate Grey/Black PDK 2019 440i M-Sport Smoke Topaz Metallic/Opel (Sold) 2014 335i M-Sport Black/Beige MPPK/MPE (Totaled) 2013 328i Sport xDrive Imperial Blue/Grey (Sold) |
06-06-2017, 10:36 PM | #9 |
54
Rep 297
If you're truly looking for 500+ whp then I say get the xdrive. It will put the power down. You can get coilovers to address the suspension.
06-07-2017, 06:25 AM | #10 |
151
Rep 545
Forgive my ignorance, but on e90 consensus was that anything above 500whp mandated only RWD due to weak transfer case in AWD. I don't know if on F30 AWD is more robust or not?
06-07-2017, 07:53 AM | #11 |
4061
Rep 4,983
RWD always. xDrive is decent, but nothing to write home about. RWD with good snows will be fine.
As for the 500hp, xdrive may help you link up slightly better, but only just so much.
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
06-07-2017, 09:33 AM | #12 |
550
Rep 373
Have you considered a used or CPO M3?
It will get you closer to your magic 500+whp number, RWD, stronger engine internals + LSD. Last edited by NWest; 06-07-2017 at 10:09 AM.. |
06-07-2017, 11:37 AM | #13 |
714
Rep 1,329
+1 for LSD
2002 325i sport - sold 2009 135i M sport - sold
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT |
06-07-2017, 01:25 PM | #14 | |
151
Rep 545
n54 only needs $1500 to make it 500hp at crank. Supercharger for M3 E92 is $10-14k alone. The closest car that has 500whp stock is F10 M5, but that beast is out of my league money wise ($50-60k for used 2014 M5 vs $25k for 2014 F30 335i M-Peformance). My numbers may be not exact, but close to it |
