06-03-2017, 12:33 PM | #1 |
1330
Rep 2,214
Went to the Dyno, Map 0 w/ full bolt on results - 6MT
Took her to a "Dyno Day" event last weekend. I neglected to confirm that I was on Map5 before handing the keys over, and after a service visit at the dealer I forgot to change it back to Map5, so I got a somewhat baseline on Map 0 instead. Mods include:
JB4 - MAP 0 VRSF catless DP w/ MPE VRSF FMIC 6" Race version VRSF CP BMS Intake Car is a 6MT, Elevation at the shop is about 1300ft, and it was hot AF inside the shop, so I'm pretty happy. IAT's wouldn't go below 100*F!! Shop must have been 120* inside we were all swamped by the end of the runs. Only getting about 1-2* of timing with those IAT's as well. Was a good time and am happy with the outcome. Pure Turbo Inlet and Meth going in next week. Will probably re-dyno next time I go to the coast, or in the Fall on the next Dyno event. Hoping to get it up around 380whp or higher. Thanks to all who've helped me along my journey, thus far! D Last edited by Dylan86; 06-03-2017 at 12:51 PM.. |
06-04-2017, 04:20 PM | #3 |
1330
Rep 2,214
06-04-2017, 07:39 PM | #4 |
341
Rep 1,184
06-05-2017, 06:42 AM | #7 |
3179
Rep 2,577
Ok I'll be 1st one to look at facts here.
It made 310+whp over only a small dip at 5k and lasted less than a period of 200rpm. In this sense, 310whp is a better and more representing number for baseline. Given the fact that dynojet adjusts to altitude, there is nothing to be happy with seeing around 315whp decatted. That leads to 300-305whp or so when stock, which is the typical American number with m235i we have been seeing. Next time with more bolt-ons installed, run map2/5 to know the delta, the only thing that matters.
Lemania 2320
FSociety3812.50 |
06-05-2017, 07:59 AM | #8 | |
1330
Rep 2,214
I'm very happy because it's running well, and is running better on the road than what you see on that sheet. Dyno #'s mean very little, as every report will vary and every dyno, day, and location will change the result. They have a sister company in Vancouver of which the shop owner claimed that location will make 20-30whp more just due to being at sea level and having a cooler climate. There are too many variables to consider with Dyno's, and I could care less if the car could or should have put down more. The writing is on the wall, if I can still make over 300whp/350tq with extreme heat soak, pre meth, I'm pretty happy! Last edited by Dylan86; 06-05-2017 at 08:08 AM.. |
06-05-2017, 08:19 AM | #9 | |
3179
Rep 2,577
BTW, take a second thought about what that shop owner said.
Lemania 2320
FSociety3812.50 |
06-05-2017, 09:02 AM | #10 | |
1330
Rep 2,214
I appreciate your input, though. Last edited by Dylan86; 06-05-2017 at 09:15 AM.. |
06-05-2017, 09:32 AM | #11 |
341
Rep 1,184
06-05-2017, 10:23 AM | #12 |
3179
Rep 2,577
Dylan,
let me put this simpler - 310-317whp on Dynojet are adjusted numbers that already reflect your car's performance in real world where timing is advanced and boost is higher. Your findings are very true, which I appreciate, but they lead you to untrue conclusions. Let's stop from here if both our points are well understood. BTW, turbo Inlet is a great bolt-on with your boost level. Do a comparison dyno. Good luck!
Lemania 2320
FSociety3812.50 |
06-05-2017, 11:08 AM | #13 | ||
1330
Rep 2,214
FSociety3812.50 |
06-05-2017, 11:18 AM | #14 |
341
Rep 1,184
[QUOTE=Dylan86;21789875]Yea it's not holding 17 just spiking for a few hundred RPM and sticks around 14-16 for the most part, but that's 2-3 more PSI than I ever see on Map5. That said, Map5 feels stronger from start to finish, and more linear as most have reported. Can't wait to get the meth hooked up!
I don't have mine hooked up currently . I decided to go from single cm 10 on 50% meth to cm 5 and 7 on 100% meth. After I swapped nozzles, I was having some issues with leaks and with purging the system properly. I am going to move my solenoid as close as I can to the nozzles. Also I'm going to replace PEX tubing with stainless braided lines and an4 fitting for safety and longevity. Still trying to figure out which lines and fittings to go with though. |
06-05-2017, 02:32 PM | #15 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
SeanWRT agree with you but this is Dynocom not Dynojet.
Dynocom reads happier than DJ btw
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
Dylan861330.00 |
06-05-2017, 03:19 PM | #16 |
5554
Rep 5,372
100+ degrees ambient temps? Yeah, that car is down on power, correction factors be damned. There are plenty of dynos out there of N55 cars, especially M2s, showing rather low numbers under hot/humid ambient conditions. Yes, dynos can and do correct for density altitude (DA) conditions, but there's no correcting for how an ECU is reacting under those conditions. Most late model turbo cars, including BMWs, get quite conservative on the power control to reduce the potential of a detonation situation, especially a low speed pre-ignition (LSPI) which is a big problem in a lot of direct injection turbo motors (not necessarily BMWs though).
Dylan861330.00 |
06-05-2017, 03:23 PM | #17 | |
1330
Rep 2,214
Again, I'm not unhappy, I get all of the factors and that's why I am good with it. The car was literally making no timing even at 6k rpm, and that alone tells the story of power loss. I know Dyno's correct for ambient temps and altitude but they can't read an ECU, or factor in timing pull and boost, but I can read a log and tell what was happening and the reasons behind the final number. |
06-05-2017, 03:31 PM | #18 | |
1330
Rep 2,214
I plan on the single CM10, with a 50/50 water/meth blend. Hoping for good times |
06-05-2017, 03:32 PM | #19 |
IG @bmwF9xG80
3813
Rep 7,593
Dylan86 props for taking your car to Dyno at least majority of others don't and think their cars makes the same power as the next car (WRONG).
107F IAT starting or at the end of the run?
06-05-2017, 04:47 PM | #20 | |
1330
Rep 2,214
The IAT's were tracking about 113-115 when rolling freely on the Dyno. He was doing his best (the operator) to load the car for at least 20-30 seconds before each pull. He even waved me over to show me what was happening. I asked him to press "Start Logging" before each run but he forgot probably because it was f'in hot inside my cabin and I didn't get a record. When I was in the car and under load on the "pre-run" we couldn't get it below 110*F the run itself I saw the lowest number which was 107*F (41*C), which is about 10*C higher than I've ever seen the car run. Sure enough I had my eye on timing advance and it might have hit 1-1.5* for the entire run but that was all the way up top once the run was basically over. Do you think water/meth would remedy this completely, or only partially? Cheers D |
FSociety3812.50 |
06-05-2017, 04:53 PM | #21 | |
IG @bmwF9xG80
3813
Rep 7,593
Yes Water/Meth injection will definitely fix this cooling issue. Also, were their fans adequate? If not I'd go somewhere else for Dyno and look for a Dynojet instead. Why didn't you just grab your mobile and logged each run ?
06-05-2017, 05:37 PM | #22 | |
1330
Rep 2,214
I tried standing with the phone in my hand and I kept disconnecting via bluetooth. It was a "Dyno Day" event and that machine is buried in the back of their shop, with a chained off entrance about 40' away, which is how far away I was standing when they ran the car. Video was done by their staff. It wasn't until he called me over that I was able to take a look at what was happening, live. Sure enough I found out after that he didn't log it as discussed beforehand.. |
