05-31-2017, 03:02 AM | #1 |
19
Rep 70
Found an oil leak
I was looking under my car today just cause my warranty is about to run out next week to check for any issues and I found this oil leak. I dont know what that part is called where it's leaking from. Anyone have any ideas what it could be? I already scheduled an appointment with BMW. Sorry for the blurry pics had to lower the resolution to upload them on here.
05-31-2017, 08:45 AM | #2 |
200
Rep 536
Drives: 2013 335xi Alpine White
Somewhat hard to tell because you don't mention where your are in relation to front, back, middle of the car...
But that black pan with fins looks like your transmission oil pan. If that's the case, then you are leaking transmission fluid and this should be serviced immediately. Have the transmission inspected as well to make sure nothing was damaged. Take your pics to BMW since you are in warranty and don't drive it if possible. |
05-31-2017, 02:51 PM | #3 |
19
Rep 70
All the pics are taken directly under the oil pan facing the rear of the car.
I feel like it's been there a while cause the oil is pretty much dry with all the dust and debris on it, so maybe residual oil from a previous oil change? I'm not sure, but I do have an appointment with BMW on Monday. I have to drive it to work for the next 4 days but I put it in map 0 and won't be on the throttle much |
06-01-2017, 08:40 AM | #4 | |
200
Rep 536
You can't go by condition of the leaked oil, that part of the car gets very hot under operation and can cook the oil and dry it out. Most likely it's only going to leak when the system is under pressure, which is why you don't see oil leaking when you took the pics. Looking at the pics again, I do see some staining on the oil pan where oil did leak, but I find it hard to believe that it would have travelled up the mating surface to the bolts and then caked around the bolt seat like that, unless you park uphill. Definitely take it easy till your appointment - stop driving immediately if you notice strange behavior from the tranny. Last edited by madmonkey; 06-01-2017 at 08:49 AM.. |
06-15-2017, 07:48 PM | #5 |
5886
Rep 10,256
It's very disappointing when a leak happens. If the engine / transmission seal is the suspect, I suggest to call BMW and have the car towed on a flat bed truck to avoid causing potentially more damage.
06-15-2017, 08:50 PM | #6 |
19
Rep 70
I took it in to BMW and it turned out to be the transmission seals. Coverage d under warranty. Luckily checked everywhere for any problems couple days before it expired. I'll post a pic of the service form I got tomorrow
06-16-2017, 01:59 PM | #7 |
200
Rep 536
Good that you caught this before the warranty ran out. This kind of service can get expensive. Pay close attention to your transmission's performance and report any abnormalities to your dealership. Make sure if there are any issues that they get logged in your service record so that in the case of failure, you have a history track they can look at.
06-17-2017, 07:53 PM | #8 | |
5886
Rep 10,256
