05-30-2017, 09:57 PM | #1 |
793
Rep 1,627
2nd gear grind with up-shift @/near redline
Hi all. I have a 2014 435i with MPPK. About 2 months ago I noticed that I would occasionally get a grind when up-shifting quickly at redline between 1st and 2nd gears. Now, it is absolutely impossible for me to up-shift from 1st to 2nd at redline without a horrible grinding noise. Would this typically be the clutch or some other mechanism. This only happens when up-shifting at or just below redline. Down-shifting into 2nd from 3rd or up-shifting below 6,000 RPM results in no grinding. This doesn't happen with any other gear. For example I can quickly upshift from 2nd to 3rd at redline without any grind.
Thanks
M4 in MG | 6 MT
05-30-2017, 10:30 PM | #2 |
648
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
It's a bad 1-2 synchro...a common problem with BMW 6MT. When I purchased mine, 2 of the 3 335's I test drove had a bad synchro. I didn't discover it in the one I purchased until the way home. The dealer replaced it under warranty at no cost.
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
Vegetable792.50 |
05-30-2017, 10:35 PM | #3 |
793
Rep 1,627
Thanks AudiA4, I figured that would be the cause, but had a few mechanics say that the clutch was probably bad.. Luckily I bought the 100,000 mile warranty as I am at 75,000 miles
M4 in MG | 6 MT
05-30-2017, 11:07 PM | #4 |
648
Rep 1,476
Lucky indeed, as the dealer told me it's normally $8,000 for a new transmission.
05-31-2017, 12:03 PM | #6 | |
514
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
First few times I did a hard 1->2 redline shift, there was a grind but I thought maybe I shifted too quickly so I've been delaying my clutch release more conservatively since then. Entering second gear does feel a bit clunky at times even shifting from other gears.
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
05-31-2017, 12:09 PM | #7 |
16
Rep 33
Interesting, I don't have an issue going into 2nd, but I get an almost "lockout" feeling going from 2nd to 3rd or 4th sometimes. I have to be very patient and wait for engine RPM to fall to match and it'll go in smoothly. This is not very confidence inspiring if it's a common issue with synchros.
05-31-2017, 02:16 PM | #8 | |
648
Rep 1,476
Generally, you do in fact have to shift aggressively at a higher RPM to induce the problem, as the higher the RPM the more difficult it is for the synchros to do their thing. If you're trying to replicate the problem for the dealer, certainly don't baby it! Or let them drive it...they know their stuff.
06-02-2017, 10:04 AM | #9 |
16
Rep 311
Yeah, they had to replace mine for a bad 2-3 synchro at 14k miles. double check the reverse switch (back up lights/camera) before taking the car back, as apparently the switch casing is pretty fragile and they can hoark it up when they swap it from the old transmission to the new one. I got the car home and was backing out of the the garage and was like hmmm something's missing here.
06-05-2017, 11:33 AM | #10 |
648
Rep 1,476
Who said he was "constantly" shifting at redline? Even if he were, it shouldn't do that...this is a sign of a mechanical failure.
Vegetable792.50 |
06-05-2017, 11:47 AM | #11 |
364
Rep 775
Agreed. Hopefully the car is still under warranty as indeed it does sound like a synchro issue.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
06-11-2017, 12:11 AM | #12 |
793
Rep 1,627
For those of you who have had your gearbox replaced, is the replacement just as prone to 2nd gear synchro failure, or has there been improvements? I'm just wondering because my car was diagnosed with having a bad 2nd gear Synchro, but what's the point if the replacement is going to be just as bad?
M4 in MG | 6 MT
06-11-2017, 11:20 AM | #13 |
5556
Rep 5,372
I also wonder how many people are shifting hard on cold transmissions and before the tranny oil is warmed up on a stone cold motor. It takes a solid 10+ minutes of driving before the dry-sump equipped 6MT found in the N55/B58 gets up to temp. Beat on the car before tranny is up to temp and you can damage a syncro on a hard and abusive high rpm on a very high torque gear change like the 1-2. Once the syncro is damaged, it will exhibit the issue, warmed tranny or not.
As far as I know, the M235 uses the same 6MT as the F3X 6MT, but in the 2014-2016 M235 literature, it notes that the M235 has beefed up lower gear syncros. Perhaps the new F3X are using the upgraded M235 6MT? I have heard of a couple of cases on M235 with damaged syncros, but all those cars were pushing quite a bit more power than stock and were raced. |
06-11-2017, 04:33 PM | #14 | |
648
Rep 1,476
06-21-2017, 10:56 AM | #15 |
793
Rep 1,627
Audi, did you have the clutch/flywheel changed at the same time?
M4 in MG | 6 MT
06-21-2017, 11:27 AM | #16 | |
648
Rep 1,476
Vegetable792.50 |
06-21-2017, 11:29 AM | #17 |
15
Rep 128
What other symptoms is known for a bad synchro?
Sometimes, when I shift from 1 to 2, I could hear like a shutter sound of something. This happens when I depress the clutch pedal. From 2 to 3, 3 to 4 and so forth, I do not hear or could replicate that shutter sound. Any ideas? I really don't know what to make of it because it's my first time owning and driving a 6MT. |
06-21-2017, 04:07 PM | #18 | |
648
Rep 1,476
06-21-2017, 06:15 PM | #19 | |
15
Rep 128
Perhaps, next time CBS lights on for service, I'll bring this up to the SA. Overall, car drives good, no issues so far. I do not upshift at high RPMs or anywhere near the redline. |
06-21-2017, 06:24 PM | #20 |
136
Rep 1,592
I think I was starting to get this on my 135i before I got rid of it. (one of the reasons I did) A few times near the end I would shift from 1 to 2 and it would pop out of gear. I had been driving it for 8 years, but it only had 30K miles on it.
06-21-2017, 06:56 PM | #21 |
e90noob
1588
Rep 1,862
i've had my '16 328i 6mt for about 15 months now
i've taken my car into 2 different dealership about 9-10 times for the "grinding" when shifting into 2nd gear ............. service technicians are unable to duplicate i'm unable to duplicate the problem when with a tech as well it's really frustrating
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22 |
06-21-2017, 09:23 PM | #22 |
793
Rep 1,627
I hope they did, but it seems like you had yours done early on in your car's life so maybe it wasn't needed. I now have 75,000 miles on my 435, so it's recommended that I get a new clutch/flywheel (while it's out) which comes to $2300 that isn't covered under my warranty. Ouch!
M4 in MG | 6 MT
