05-30-2017, 08:25 PM | #1 |
18
Rep 45
What do I need for Pureturbos stage1?
Hey guys, im planning to get the stage1 from pureturbos upgrade, my car is FBO already, catless dp, chargepipe, FMIC, intake, forge dv, mpe and jb4. Would I be needing anything else?? Is meth completely necessary? Or any other injection kit is a must for this stage?
Thanks for the help guys. |
05-30-2017, 08:42 PM | #2 |
1165
Rep 1,931
dont even bother with stage 1 turbos. Go straight to stage 2.
You can just bolt up to what you have today for an additional 30whp. max 450 whp with meth. 600whp with port injection. You are going to need to increase fueling in order to really get the most out of them. -stage 2 lpfp -Meth or port injection. - backend flash tune (bm3 or other) i would say go port injection, with stage 2 turbos and a PI kit running 93+ e85 you can easily get to 600whp. I would keep it conservative under 25 psi, which will be around 56-580 whp. The good thing is, my friend is selling everything you need since he's selling his car. PM me and i can get you in touch if interested. He would need your current turbo and oem fuel pump if you wanted to swap.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
05-30-2017, 08:56 PM | #3 | |
18
Rep 45
But thanks anyway! |
05-30-2017, 09:31 PM | #4 | |
341
Rep 1,184
Guys have been running stage two without injection or fueling upgrades and been getting about 450 whp. Then it leaves room for expansion later down the road. Or do what I did and add meth to your fbo car. It truly is a pretty large difference. On map 2 I hit 12-13 psi. On map 3 I hit 19-20 psi. I haven't dynoed yet but people say fbo plus meth equal 390-425 whp and 450+ wtq. |
05-30-2017, 11:12 PM | #5 |
3179
Rep 2,577
BM3 alone can handle PS1 well without needing JB4 for boost control.
Meth is not a requirement but it's the single greatest power making bolt on available for F N55 platform, it would net you more than a PS1 turbo. Follow your heart, there is nothing wrong with pursuing "only" 30whp upgrading your turbo. There're plenty of people that is not interested in making ridiculous whp numbers and having to live with the hassle out of meth, PI & etc. Let us know what you end up doing. Good luck.
Lemania 2320
05-31-2017, 09:14 AM | #6 |
1165
Rep 1,931
stage 1 doesn't really give you much for the price. You are better off saving a little more and getting a stage 2 kit or running a flash tune.
A turbo kit with no fuel mods is kinda pointless. I make more power than it does on stock turbos on a flash tune.
www.nybmwcca.org
05-31-2017, 09:53 AM | #8 | |
341
Rep 1,184
From what I have seen Fbo + PS2 = 450 whp Fbo + meth + PS2 = 530 whp Fbo + port injection + lpfp + PS2 = 600whp The reasoning would be why go through the all the trouble of upgrading to PS1 to be capped around 450 whp when you could spend a little bit more and have the option for much more power. If you have the mod bug like many do, you will want to upgrade down the road. The other end of the argument is you could spend way less on a wmi kit and be making close to what the PS1 makes. In the end it truly depends what your goals and budget are. For me adding methanol was exactly the bump in power I was looking for. |
05-31-2017, 10:10 AM | #9 |
1165
Rep 1,931
to go above 21 psi you also need a n20 tmap as well.
www.nybmwcca.org
05-31-2017, 11:26 AM | #10 |
341
Rep 1,184
06-01-2017, 07:48 PM | #11 |
1330
Rep 2,214
If I wanted 400whp before meth, what would you guys suggest? Pure Stage 2 with JB4 only? I can't see myself requiring more than 4-420whp for my intentions, to be completely honest..
My initial thought was that this car would be perfect on a stock turbo making 400whp, but that seems to be it's absolute limit and definitely maxing out the main component. So if I could go PS2 with the JB4 to achieve that without as much boost, etc, I'd be cool with that. I don't need or want anything stupid in the car for power, I just want to be at that limit of grip on a sticky tire coming out of a third gear corner. The car still has some more room in it before getting stupid, IMO, and I'm FBO/JB4 (meth in a week or two) at the moment. |
06-02-2017, 06:50 AM | #12 | |
341
Rep 1,184
I would try that first and see how you like it. Call me crazy but I would say the power increase from meth is the same, if not more than fbo map 2 over stock. I heard someone on n54 say that 1psi increase is roughly 9 whp. Fbo map 2 I was hitting 13 psi and with meth I hit 19.5. obviously boost is not everything as timing plays a role too. Trying to tie this back to op's post. Your options for getting 400whp+ are too; Add meth on stock turbo Add meth and E30 on stock turbo Flash tune with jb4 and fuel it stge 2 lpfp with e50? ( Brian may know more about this, I think he has upgraded fuel pump) Upgrade to PS1 Upgrade to ps2 That should be in order from cheapest to most expensive, and easiest to most difficult install. |
Dylan861330.00 |
06-02-2017, 08:25 AM | #13 |
3179
Rep 2,577
Did OP say anything wanting to go above 21psi?
It's perfectly fine a stg1 turbo build doing 16psi flat without meth & PI s*t.
Lemania 2320
06-02-2017, 03:23 PM | #14 | |
341
Rep 1,184
I think the point we were bringing up is " if you go stg 2" then you will be able to expand down the road if you so choose. In that case you would need pi, dv+, tmap, etc. |
Dylan861330.00 |
06-02-2017, 06:12 PM | #15 |
1165
Rep 1,931
to get to 400whp...
Go with stage 2 lpfp. Change plugs to n20's or s55's. Run 4 gallons of e85 or ms100. Get a flash tune, you can keep jb4 if you want, just get a backend flash. Cattless DP, FMIC, CP, turbo inlet will help. You'll want to be around 19-21psi on peak even on stock turbos its fine. This should easily get you to 400, or right around there depending on your fuel choices. If you want more, add meth... If you want even more after that, upgrade your turbos.
www.nybmwcca.org
Dylan861330.00 |
06-03-2017, 12:01 PM | #16 | |
1330
Rep 2,214
Thinking meth would be the end-all answer to those issues. It's sitting in the trunk, installing this week coming. Thanks for the advice Ideally, I'd go PS2 once the oem turbo pukes, but the mod bug has a way, with me.. Last edited by Dylan86; 06-03-2017 at 12:08 PM.. |
06-03-2017, 05:17 PM | #17 | |
341
Rep 1,184
Dylan861330.00 |
06-17-2017, 04:10 PM | #18 |
Car Enthusiast
282
Rep 501
What meth kit are you guys using? BMS? aquamist or snow performance
2016 M235 - Melbourne Red
2005 BMW M3 - Sold Licensed Automotive technician for BMW Regina |
06-17-2017, 09:37 PM | #19 | |
3179
Rep 2,577
Lemania 2320
06-19-2017, 07:57 PM | #20 |
Joint Chiefs of Staff
24198
Rep 190,805
No additional mods needed for the stage 1
06-21-2017, 02:26 AM | #21 |
595
Rep 1,693
The N55 turbine is tiny and the Stage 1 does not upgrade the turbine. If you push it, it'll have a huge amount of exhaust back pressure. I'd highly recommend going straight to stage 2.
Ditch the JB4 and run a custom Bootmod3 flash tune. |
06-28-2017, 05:39 AM | #22 |
Car Enthusiast
282
Rep 501
What Meth Kit is everyone Running?
And For someone who may want to make those crazy HP numbers, How would you go about it If E85 isnt accessible to you. I dont know of any local fuel stations that run E85 at the pumps here in Canada.
