05-30-2017, 08:36 AM | #1 |
56
Rep 152
Help me identify this part near intake
I have to replace a part that's got a missing piece of plastic where the clamp goes. I'm not sure what to call it to search for the part - can anyone identify what I might call this section?
05-30-2017, 09:02 AM | #2 |
1165
Rep 1,931
Your charge pipe is broken and needs to be replaced.
It's the c-clip that holds it, the charge pipe on. see below. You shouldn't be using a metal band clamp. If your charge pipe broke, this is very common. Its probably time to change the charge pipe to a metal one, ER or other brand. You can have bmw replace, but if you are tuned, it will keep happening. Make sure you have the o-rings and the c-clip or you will have a boost leak.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic Last edited by bryan_G01; 05-30-2017 at 10:24 AM.. |
05-30-2017, 10:43 AM | #3 |
56
Rep 152
Excellent thanks - I still have the C-Clip.. it was hanging on one of the wires in the engine bay and luckily I found it before it fell!
Chargepipe was exactly what I needed to know so I've got one on order since mine is cracked. Any suggestion on a downpipe fix? I need to pass inspection soon too. I've read about the vrsf downpipe and the ****** catsim - just want to make sure one of those is a suitable solution with the jb4 to get me passed inspection. |
05-30-2017, 01:04 PM | #4 |
1165
Rep 1,931
in NY, the first 2 years of the car, they just give you the sticker.
See what your state laws are. If you are past that, just clear the code before in the parking lot before they run any tests. Put jb4 in map 0, and disconnect it via obd. Most say you will need to replace ur DP with stock to pass. Will that tool trick it to pass? No idea. I run a flash tune, and all my emissions are passing under my logs with a cattless dp.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
05-30-2017, 06:05 PM | #5 | |
341
Rep 1,184
