05-29-2017, 08:14 PM | #1 |
Rep 51
Leak after Charge Pipe/FMIC install
Hello,
Still learning about the f30 and not sure what I'm looking at. The car is a 2013 335i M. This connection is located in the drivers side grill area where fog lights are generally located. I was able to google and determine that this is an Auxiliary Radiator used for extra cooling on M Sport vehicles. I forgot to attach the line under the FMIC back on the clips when I finished with the car and drove it once with them not hooked in. This is the end of that line. I'm not sure if I have somehow damaged the connection or if perhaps there is an O-ring inside that was somehow damaged. Has anyone removed this line? I'm not exactly sure how to remove it and the shop I want to take it to cannot get me in until next week. Last edited by shaunbhere; 05-30-2017 at 09:05 PM.. |
06-01-2017, 01:50 PM | #2 | |
153
Rep 438
Drives: F30 335i M Sport
06-02-2017, 02:59 PM | #3 | |
Rep 51
Since I removed the connection I also ran the water pump to bleed the lines and get all of the air out. Will update again once I have driven the car around a bit. |
xxxjecxxx2153.00 |
